Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Turned up the volume on the TV and after releasing the button the volume continued to increase to maximum. Now other buttons or remotes will work. Have to unplug the TV to turn off and when plugged back in returns to the same status - max volume and no buttons or remotes work. What's up?
  • 10,515 Answers
There could be many reasons.However, it is more suggestive of a ' Faulty Remote ' than anything else. Before we start blaming the TV or anything, change the remote. I am pretty sure that this would solve the issue.
Let me know, the update.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 28, 2010
  • 1 more comment
  • cscarp Jul 28, 2010
    Already tried changing remote and just retried it again and there is no change in status.
  • taran_2005
    taran_2005 Jul 29, 2010
    Thanks for your response!!
    Then, it would be a rare hardware failure. If you have experience in repairing electronics, could read schematics, knows how to use multimeter and soldering iron and would keep all the precautions, revert and i would tell you few pointers that would help you to fix the TV.
    Let me know,so that we could proceed..
    Hope i helped you.
    Thanks for
  • cscarp Jul 30, 2010
    I have those skills and tools but don't know if I would have the time anytime soon to get r' done. What is you guesstimate on what it would cost to have a professional tech take care of the issue? Thanks.
37 in. Viewsonic TV volume steadily increases up to maximum 100. unable to control it until i pull the power plug
Either the button is jammed on the remote or the TV itself. Try removing the batteries from the remote. If the doesn't work, it is probably the actual button on the TV, in which case you would have to try and pry up the button and manually pull up the pressure pad underneath.
Nov 29, 2012 | Televison & Video
CHUNGHOP RM-311E code for LG television
couldn't find the code for lg but this should do the trick
Automatic Code Searching
1. Turn on the TV set by hand. Point the controller at your TV set.
2. Press 'Set' button continuously, then press 'power' button, and release the two buttons simultaneously. At this time the light is on.
3. Press the '+' (or '-') button of volume once, pay attention to the volume of your TV to see it increase or decrease. Repeat this action until the volume changes. Then press 'set' button once. at this time the light is out. Set up is finished.
Jul 26, 2011 | LG Televison & Video
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
Jul 02, 2011 | Televison & Video
Sharp tv ...want to use Rca remote D770 how do I program the remote?
Press and hold the device button you want to program (TV). Then type in one of the codes for Sharp TV's:
1004, 1006, 1012, 1029, 1095
1111, 1112, 1113, 1122, 1171, 1173
Release the TV button and press the on-off button. If that doesn't work, press the device button and try the on-off button again. Continue trying codes until one works.
Another thing to try: Turn on device. Press and hold the button for device you want to program, press the on/off button and hold until the LED turns on, and then release both buttons. Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off. When the device turns off, stop pressing play. Press REVERSE, wait two seconds and continue doing this until the device turns back on. To finish programming, press and hold STOP until the LED turns off.
If neither of these methods work, the remote probably isn't compatible with your TV (manufacturing dates matter; newer tv's often don't work with older universal remotes). In that case, try remotes.com for a exact duplicate of your TV's original remote. http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=19C140&uuid=12795625009490
I hope this helps.
Jul 19, 2010 | Sharp 19C140 19" TV
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Low sound when converter connected
use converter volume button to increase the volume to the maximumthen use the tv remote to increase again up to the maximum. After to increase or decrease use only one remote.
Thank you for voting for me if itworks.
Jul 11, 2009 | Televison & Video
How do i program my remote
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
Aug 25, 2008 | RCA DISH Network(r) 311 Satellite System
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
