Question about Dell 3100cn Laser Printer
Dell 3100cn-smudge When I print to the 3100cn, there is a smudge on the same place every time I print.  Can I clean something to correct this problem?
  • kurtg Oct 27, 2008
    same thing heren i've tried the 2 steps as advised but no result.
I had the same problem and loosened the 2 screws on the top of the dell drum unit. After that, the streaks disappeared. Dell manufactured defective drums!
Posted on Oct 26, 2008
    Scholar:
  • 99 Answers
The print toner cartridge has a small trap door that opens to let the toner adhere to the paper. Remove the toner cartridge and locate this moveable panel on it. This roller is VERY sensitive, and can scratch VERY easy. Use a soft LINT FREE cloth to GENTLY wipe the colored roller if you see any toner build up. If that does not clear up the problem you will need to replace your Fuser Unit which will need to be ordered from Dell or a 3rd party supplier. Its a pretty easy process, and instructions usually come with the fusers. If you have a printer warranty they will fix it for you. Thanks! //CowboysfanZ
Posted on Apr 24, 2008
My dell 3100cn won't print, even though it says the printer is ready
look inside of printer.see if something is pulled or unpluged. see if there is ink and paper inside.
Jun 20, 2013 | Dell 3100cn Laser Printer
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Cheers
Oct 22, 2009 | Dell 3100cn Laser Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Dell 3100cn (color printer): color smudging
Smuding typically occurs when you print on a heavier paper without changing the settings. By changing the settings to a thick paper type, the page will be send through the printer more slowly. this will likely eliminate the smudging.
Cheers.
Sep 24, 2009 | Dell 3100cn Laser Printer
I have a Dell 3100cn printer that seems to always print with a thick gray streak down the middle of the paper. Apparently, the drum was replaced a couple months ago and this problem only began recently. ...
try the cleaning rod. goto: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
and see the instructions under "replacing the cleaning pad" to access the cleaning rod. You likely do not need to replace the pad. To use the rod, pull it out and push er back in 10X.
Cheers
Jul 08, 2009 | Dell 3100cn Laser Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Printer has two smudges in same place every time
The reason you see a smudge in the exact same place everytime is due to ink being on the roller. Solution: using good light, use isoprel alchol on a cotton swab to clean the roller. Ink on the roller is also an indication that your head cleaner pad (look really good on the right hand side <inside> for the pad) is dirty. If you've not done so in the past, just flip it over and like magic you have a clean pad...just dirty on the other side.
Dec 17, 2008 | Dell 924 All-in-One InkJet Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Bleeding color
I have a similar problem. I just spoke with Dell support and they said that the problem is the printer drum. Fortunately, my printer is under warranty so they are sending me another.
Jan 23, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
571 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
