Question about Akai LCT3201AD 32 in. LCD Television
Self powering down
I have a AKIA LCT3201AD
T.V and when it worms up it will power on ,
then as soon as it does it will power it self off.
it wont stay on for more then 30sec. to 1min.
please help me...
  • dishspacer1 Jul 28, 2010
    i took the back off and placed a house fan blowing on the board and power supply area it still does the same thing??
  • 1,056 Answers
You can put a small fan inside where you suspect the over heating occurs. Place it so that it blows air to the aluminum heat sink. This is probable the easiest way to fix it. I fixed TVs for customer this way before and they never took it back to me. Be carefull where you get the power from your fan.
Posted on Jul 28, 2010
When I plug my worm light into my GBA it shuts off?
it sounds like the light is shorting out and thats why the GBA turns off to protect it's self
Dec 16, 2013 | Nyko Worm Light Advance for Game Boy...
My 89 f150 lacks all power
SOUND LIKE FUEL FILTER STOPPED UP.
Feb 15, 2010 | 1989 Ford F 150
Canon I9900 self test
You might be able to initiate the self test by powering it off first. Then, when you power it on, hold the power button down for 5 to 10 seconds continuously. In many cases, that will start the self test to run, But hold the button down for 5 to 10 seconds without letting it up at all, upon turning it on.
Jun 12, 2009 | Canon i9900 InkJet Photo Printer
Akia lct2070 screen went black and will now shut its self off
You may need new inverters, CCFL's, or your power supply is not [providing regulated 24 volts...
Inverters
CCFL assembly
power supply
We have these Akai boards in stock if you need them.....
Dec 25, 2008 | Akai LCT2060 Television
How do use self clean service?
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
lock will begin to close automatically and the "LOCK"
indicator light will flash. DO NOT open the door while
the light is flashing (it takes about 15 seconds for the
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
temperature has cooled.
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
and the "LOCK" light has gone out, the oven door can
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
appear in the display.
NOTE: When the oven is cool, wipe away any residue
or powdered ash with a damp cloth or paper towel.
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Akai lct3201ad power don't turn on any more
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 28, 2008 | Akai LCT3201AD 32 in. LCD Television
I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Oct 10, 2008 | Akai LCT3201AD 32 in. LCD Television
AKIA LCT42Z6TM
You have the same problem that most people that have this unit do. I had the same problem and fixed it. can fix this, as I have fixed 4 of these units already. Email me if you want more info tommy@ruden1.com
Jul 09, 2008 | Akai LCT4216 42 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
82 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
