Question about Kenmore 22422 Top Load Washer
My washer is leaking brown fluid and the moter runs but the drum doesnt work
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the following Whirlpool Service Manual for top load, direct drive washers
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to release the console, pull the cabinet (to check where the leak is coming from) and how to pull the pump, motor and gearcase.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=7b97579f27923039de87c5ad6ef1ed8f
It sounds from your one sentence description as if you have more than one problem.
NOTE: MOST REPAIRS ON BASIC TOP LOAD, DIRECT DRIVE WASHERS ARE RELATIVELY EASY AND INEXPENSIVE TO FIX.
First, pull the cabinet.
I'd pull the pump and motor and check the motor coupler, a common cause for the drum not spinning. I ASSUME THAT IT WILL NOT AGITATE EITHER:
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
While you have the motor and coupler out, I'd also pull the gearcase (See the above) and check to see if the lid on the gearcase is leaking.
If it is, I'd remove the 8 bolts holding the top on and run a bead of gasket material (sears and others have tubes of sealant) around the case and carefully replace the lid.
You'll have to pull the clutch to take the cover off:
See the above for how to take off the clip holding the clutch on:
NOTE: YOU DON'T HAVE TO PULL THE AGITATORS OR DRIVE COUPLER TO GET THE GEARCASE OUT.
While you have the gearcasse out, I'd also check the gaskets at the bottom of the tub to make sure that they aren't leaking.
Posted on Jul 28, 2010
Volvo washer fluid pours out into engine, doesnt spray
open the engine cover bonnet as we say in the uk. look to the back of the bonnet you will see the rubber hoses that fit into both the nipples for your washers .refit the hoses.
Nov 27, 2013 | Volvo Cars & Trucks
I have a 1987 Vette that has never dripped anything onto the driveway, until last night. It is really leaking good all of a sudden. Where should I look first.
First you need to identify what's leaking? What color is fluid? Green, Red, Brown? and where under car is fluid leaking from center, front rt, etc... Another option is check ALL fluid levels - coolant, oil, power steering, transmission.
Mar 05, 2011 | 1987 Chevrolet Corvette
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Washer leaking water
Hi there.i have a feeling that maybe the thin tube that runs from the water level pressure switch has come off the righthand side of the bowl & water is coming out of it.if thats the case the machine would never stop filling even at lowest setting.can you let me know what you find.
Jun 03, 2010 | Whirlpool LSR5132PQ Top Load Washer
Windshild washer fluid not squirting in front.
They use same fuse, See if you hear it running when you depress the washer button. If not, check for power at the Dark Blue Wire at the washer pump. If it has power, and the Brown wire is grounded. then the washer pump should work, if it doesnt , replace the pump. The washer pump Dark Blue wire shoul dbe hot and the switch grounds the Brown wire.
Dec 16, 2009 | 1997 Plymouth Voyager
Banging noises and leaks brown fluid. I can't see anything in the drum or at the back of the machine.
try to open the back of the washer, you'll see the drain pan filter, try to clean it, about the noise, see if the belt is still aligned or the bolt holding the motor are stil intact. if the belt is too loose, try to tighten it a little bit
Oct 31, 2009 | Washing Machines
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
2000 ford explorer wiper fluid pump does not work,
the fuse is located in the inside fuse panel position 12. it is a 7.5 amp fuse and is brown in color. if you cant find the position #12 then check all 7.5 fuses.if no fuse is blown then open the hood and get someone toactivate the washer pump while you lisen for it to run.the pump is located in the bottom of the washer fluid resavor and is usually replaced with the resavor as a assembley.if no blown fuse and u cant hear the pump running then you will need a new pump.if u hear pump running but no fluid is coming out look for a leak in the lines.
Jan 13, 2009 | 2000 Ford Explorer
SPOTS ON WHITE CLOTHES
if your washer has a slight rumble noise when on the spin then it is most likely that your bearings are on there way out,what it is is the bearings have grease in them and once the bearings start to go this grease starts to leak into the drum which is what the brown spots are it also leaks at the back around the bearing at the back of your outer drum and also leaks onto the floor this will need fixing by a domestic appliance engineer but it is sometimes cheaper to replace the washing machine
Oct 17, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
281 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
