Question about JVC DR-MV1SU DVD Recorder/VCR
My DVD disc not recognized after loading, how can i fix it? My JVC VHS/DVD recorder combo does not recognize all dvd's. It plays about 1/2 of the dvd's I insert. The others say disc error. All of my VHS tapes still work. It's so frustrating, I never know which one will work. Any suggestions on what may be causing this?
Ya know, this has caught me a few times, and I'm a video production engineer. I've experienced this on not only desktop models of laser/disc media, but on internal drives for computers as well. Believe it or not, in MOST of the cases, it turned out to be something so simple that I've flogged myself each time. It's something that a lot of us just seem to forget about over time. As you said, your tapes still work, but, in time, you'd start having issues until you did some routine maintenance. (Incidentally... one has nothing to do with the other) I don't know how long you've been using your machine, but here's something to try... CLEAN THE OPTICS! I had the same situation with one of my internal DVD drives (as well as CD) in the not too distant past. I didn't get why some discs would play and others wouldn't. In my line of work, troubleshooting and analyzing come with the territory, but in this case, I simply over thought the problem. It finally dawned on me that the problem might be that the laser can't read the disc properly, and why?... we'll... it has been some time since I actually pulled the drive and CLEANED IT! This would consist, in simple form, of opening the drive transport area, and blowing it out with a can of air, checking the loading mechanism to see if the gears need lubrication (use the right stuff... usually white grease is ok), then CLEANING THE OPTICS! This means locating the lens, and literally cleaning it's surface. I understand that there are many who would not want to tackle this, but it's really not that hard. The hardest part is to actually 'gain entry' to the transport area. This is where the disc sits on a spindle, and a mechanism that houses the optic lens moves (back and forth) over it. When you get it apart, you'll figure it out. It's generally easier with desktop type units (which yours is) than internal computer types, but I've not had a lot of trouble with either. You'll need the proper gear: Q-tips or chamois, necessary hand tools to get at what you need to, and an 'I can do this' attitude. Just take your time and think. Concerning cleaning the lens, you'll need a cleaning agent. DO NOT USE ANY TYPE OF SOLVENT. As a matter of fact, in a pinch, you could use alcohol, but believe it or not, try some good old fashioned Windex. Hell, it is glass, after all! Spray a little on your Q-tip or chamois (if you know what that is... I'm not gonna explain it here) and, once you've gained access to the lens, GENTLY clean the surface in a back and forth motion. I've found that it would REALLY help if you do this a couple of times, then wipe the lens surface with a CLEAN, DRY Q-tip or chamois to finish, as I've actually done this, still had the same issue, wasted more time troubleshooting, just to try this again, and find it solved my problem.... FOR A GOOD LONG TIME!... of course, until the cleaning needed to be done again. Be GENTLE with the lens transport assembly. It's delicate, and can be easily damaged. DON'T LET THIS SCARE YOU. You can do this... again, it's not that hard. Just be careful. I only wanted you to know this so you don't gorrilla the thing and end up having to replace the unit. Forget having it fixed if this is destroyed. The cost would exceed a new one. If you really don't feel comfortable messing with this kind of thing, I would say, 1, I think that anyone of reasonable intelligence can do this, and 2, ok, fine, then take it to someone and let them do it. Remember, though... if it isn't a buddy, he's gonna CHARGE ya for it! Once you've completed your tech work, put everything back together and see what happens. I've found this to be the problem in a majority of the issue type you describe. It's one of those "oh, yeah... I forgot it could be as simple as that...' kind of things. Ever forget?... happened to me... Of course, there are no guarantees here, but at the very least, you'll end up with a clean unit. Good Luck!... Maybe next time we can talk about how to clean the 'VCR' section of your unit... :-) JLB
Posted on May 10, 2008
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
Problem with DR-MV5S JVC Recorder
No! that should not be a factor, there are any number of reasons the VHS is not working, broken belt, idler assembly issues to name a few, I suggest a professional.
Mar 08, 2012 | JVC DR-MV5S DVD Recorder/VCR
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
I have Toshiba D-VR660KU, I've copied several VHS
you need to finalize the disc or "make compatable" or "close session". basically the disc needs to be finished off to be able to play on any dvd player. dvd-r will normally play on any player as it is the standard format dvd discs. dvd+r/rw discs do not need to be finalized, but don't play on all machines.
May 22, 2010 | Toshiba D-VR4 DVD Recorder/VCR
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Problem with reading discs
Greetings,
Try a DVD lens cleaner first, if it doesn't fix the issue, the player is bound for service because lens die out.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
JVC DR-MV1SU DVD Recorder/VCR Logo
217 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
