Question about Canon (5083A002AA) Binocular
Water inside of the lens - Canon (5083A002AA) Binocular
  • 906 Answers
Link
Kindly refer to above link to contact the Canon support team for the immediate repair of your binocular.
Thank you.
Posted on Jul 29, 2010
Moisture inside headlight lens dodge ram
that usually means there is a crack somewhere which you cannot see.
I just replaced my left headlight assembly on my Chevy S-10 paid about $75.00.
May 02, 2014 | Bosch 1994-2002 Dodge Ram 2500 Water Pump...
Fell into water, still can used, but got watermark inside lens.
You can use some absorbents to dry off the residual moisture but the marks might remain due to stain of the water. So try to use a hair dryer to warm the camera very carefully. Once there is no trace of water, but the marks remain on the lens , then it is important to remove the lens assembly after dismantling the camera so as to clean the lens using proper lens cleaner.
Attempt only if technically inclined and with proper tools.
May 04, 2011 | Cameras
Water inside trying to clean
Why are you using water , which contains impurities
I use alchohol impregnated lens wipes which you can buy over the counter for cleaning spectacles, it also evaporated quickly
Use a lens cloth to polish the glass as it dries off.
Do not over do the application of any liquids on lenses as over time it will seep through the the various elements of the lens causing them to part company and your bino's will lose their sharpness
May 27, 2009 | Praktica Roof Binocular
Water inside the lens (Canon EF-S 17-85mm F4.5-f5.6 lens)
if it is only fogged you can blow hot air on the lens while fully zoomed in and after the water has evaporated, zoom out to compress the moist air out. do this several times.
May 23, 2009 | Canon Cameras
I have a finepix s6500fd and recently dropped it in a river. The camera has dryed out very well and works, but I have now got water marks on the inside of the lens. How can I get into the camera to clean...
Unfortunately, the lens on the 6500fd is not a removable lens, and if the water is on the inside of the glass, you will want to send it in for a good cleaning.
The problem with electronics getting a bath is that although it works now, after drying, the water that was inside will promote corrosion of the internal workings of the camera over time. I would definitely send the camera to Fuji or to a qualified service center and have them give it a good cleaning to slow or prevent the decay of the insides of the camera.
I hope this helps.
Oct 04, 2008 | Fuji Cameras
Water spot inside the lens on my Lumix camera
DON'T EVEN TRY TO TAKE THE LENS OFF!!!
To take the lens off, the camera has to be dismantled, and unless you are an experienced technician, there is a 95% chance that the camera will have more problems than what it started with.
Have you taken any pictures with the water spot inside the lens? If it is visible in pictures, then you have several options:
1. Ignore it.
2. Leave it there and use an image editor to clone out the spot in the picture. (Recommended).
3. Take the camera to a repair shop, or mail it to Panasonic's service center. This is the expensive option, to remove the water spot, the price most likely will be well over $100.
4. Buy another camera. The FZ7 is rated to about 50,000 shots, so if you are approaching this number they it may well be worth it to just get another camera.
Unless the spot is seriously affecting your pictures, then leave it there. By having the camera opened there is a high chance that other problems will be introduced, such as: fingerprints,dust or hairs inside the lens or misaligned lens elements.
My FZ7's lens is full of dust, yet this is not usually visible in pictures, when it is, I can usually remove it on the computer.
I would recommend taking the camera to a service center as a last resort.
Jul 10, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Dried water droplets on inside of lens
The camera lens will have to come completely apart, and all the pieces be cleaned. This is not something you can do yourself at home. Because there is water in the lens, there is the risk that the humidity will cause corrision of some of the pieces and electronics inside of the lens unit.
You an try leaving the camera in a dry warm place that is not more than about 100 deg F for a few days to see if the water will dry out. But, I am sure that there will be water stains inside on the lens surfaces.
Jerry G.
May 16, 2008 | Olympus Cameras
I need to know how to remove the zoom lens to clean a water spot inside.
well u can, but u will need to know what are u doing, i repaired many lens when i worked in olympus, but gives lots of work.
Dec 14, 2006 | Olympus Camedia C-5500/C-55 Sports Zoom...
Canon (5083A002AA) Binocular Logo
93 people viewed this question
Top Canon Optics Experts
old marine
old marine
TC CAMERA REPAIR.Com...
Are you a Canon Optic Expert? Answer questions, earn points and help others
