Question about HP NB199UA Pavilion Notebook
My hp Pavillion dv4 will not boot. For a while it has been having problems waking up from hibernation mode. I always did a hard restart and after a while it would boot back up normally. I have had problems with the fan and heat sync in the past, but at the moment they are both cleaned and free of dust. When I press the power on button, the quickplay bar lights up. The capslock and numberlock buttons also flash. There is a noise from the CD/DVD rom that indicates that the computer is trying to boot. There is no sound from the hard drive, however. The computer does not turn off and just stays in the mode of trying to boot without being able to. The screen is completely black (no flashing bar at the top of the screen) and will not run BIOS. Is this a hard drive problem or something else?
  • eringi Jul 29, 2010
    Damilare,
    Thank you so much for your reply.
    I tried the things you suggested.
    There is still no change from before.
    Even with the harddrive out the screen remains black.
    Could it be a problem with something else that is not the harddrive or the RAM?
  • 358 Answers
Even though a lot of things might have gone wrong and caused this,
But I will try and tell you some troubleshooting steps that you can try.
First of all, disconnect your battery from back of the laptop, and try to power your laptop without the battery there, if it powers up, then just get a new
battery.
Second, get a screw-driver, remove all the RAM(memory sticks) at the back of it, clean their interface with an eraser, and try to power it on first without
them, then replace them back and power it on.
Alternatively,
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
Also from what you have just said, I suspect that your hard drive is likely to be corrupt, or having a bad sector on it.
To be sure of this, disconnect your hard drive from the laptop, and power it up without connecting the hard drive, if it boots up to the point where it says:
"Operating System Not Found" or "No Bootable Device Found", then that shows that your hard drive needs replacement
Kindly Let me know how it goes.
Hope this helps.
Posted on Jul 29, 2010
Testimonial: "Thank you very much for your easy to understand, prompt, and kind reply. You're great!"
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
No boot on a HP Pavillion dv4-1428dx
The real problem is with your laptops GPU
read this article so you know what to do.
Your Laptop Stops Working But Why Does it Fail
If you want to fix it, take out the motherboard and send it to have it repaired. Its called reballing. Look for it in the internet.
good luck.
Nov 12, 2017 | Computers & Internet
What's HP Pavillion dv4-1313 dx monitor does not come on
SEEMS THAT THE OS IS UNABLE TO BOOT.GET THE INSTALLATION CD AD BOOT THE SELECT REPAIR.
Apr 21, 2012 | HP Pavilion dv4-1140go Laptop
Hp pavillion dv4 notebook usp ports not working
Try a system restore, take the laptop back before this became a issue.
Mar 25, 2012 | HP Pavilion dv4000 Notebook
Computer will not wake up from sleep mode
- your comp is in hibernation mode
- go to control panel>>power management>>put to NEVER the sleep mode,hibernation,HDD,battery
- restart system
Mar 25, 2010 | HP Pavilion dv2000t Notebook
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Computer goes in to sleep/ hibernate mode and I can not wake it up without shutting it off, and restarting
If we are talking "hibernate", then that's what the computer does - it saves the whole memory contents on the hard disk and shuts down. You then have to power it up and it boots like always on power up, but instead of loading the system the usual way, it reads the hibernation file and restores the state in which it was when hibernated.
"Sleep" or "standby" mode is different - the system stops execution of all the running programs, switches the processor into low-speed, low-power mode, executing only the basic functions of waiting for wake-up signal. Depending on machine and settings, it will be woken up by keyboard event, system event (like laptop battery running out - time to hibernate), network activity, or the power switch.
It should wake up when the Fn key on keyboard is pressed, the lid is lfted up (if it was closed of course), or when you momentarily press the power button. If it does not, then something is wrong with your ACPI/Power Management setup, and/or there are some drivers missing or corrupt. You can try going to IBM/Lenovo website and looking for updated system drivers for your model.
Dec 03, 2009 | IBM ThinkPad T43 Notebook
Wont come outof hibernation goes to a black screen even upon rest
RESTART IN SAFE MODE.
OR
REBOOT SYSTEM, BEFORE IT BOOTS PRESS
F6 UNTIL YOU HEAR THE BEEPING NOISE, THAN STOP AND SELECT SAFE MODE
THAN CONTROL PANEL AND SELECT POWER OPTIONS
POWER BUTTON OPTIONS
Mar 14, 2009 | Computers & Internet
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
HP NB199UA Pavilion Notebook Logo
2,319 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
