Question about LG Dare VX9700 Cell Phone
Lg dare touchscreen is not responding properly
If i touch 3 an 8 might show up. If touching a name in the contact list, the screen may scroll. I am really not able to use the touchscreen dialpad or text. I repeatedly hit an option 7-10 times before it might register. I tried to callibrate it but the message. "touch accuracy not within range try again", comes up. Please help, past warranty. Thanks!!
2 Suggested Answers
erickson_kj
  • 10 Answers
SOURCE: lg dare Touch accuracy is not within the range
Go to the main menu, settings and tools; touch settings : and then select calibration and touch the six targets to calibrate touch accuracy
Posted on Sep 06, 2009
My LG dare will not respond when i touch the screen!!!:( it is very frustrating. I have tried turning it off and on and taking the battery off but there is still no response.
Hi, why the touch screen of the phone is not responding is because the touch screen of the phone is damaged, might be caused by hitting the phone on the flow or hitting the phone somewhere.
You will need to replace the touch screen for it to respond to touch.
Take care.
Sep 14, 2010 | LG Dare VX9700 Cell Phone
I have a lg dare and the touch screen is not responding
Try calibrating your touch settings.
  1. Go to settings
Aug 19, 2010 | LG Dare VX9700 Cell Phone
My buttons on my phone works but my touch screen is not responding to anything at all.
check MENU settings may be touchscreen is off ,else touchscreen loop is broken
Aug 02, 2010 | Cell Phones
Touchscreen is not working.
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jul 06, 2010 | LG Xenon GR500 Cell Phone
I have dropped my lg Dare and now the touchscreen only works part of the time. Everything else is working normally. Can the screen be fixed?
yes of course, it can be fixed. If you have a phone screw driver, you can open the phone and check if the touch screen flex is well fixed. It might be that it has disconnected or not firm to its normal position when it dropped on the floor.
But it you can check it your self, you can take the phone to a repairman.
Take care.
May 21, 2010 | LG Dare VX9700 Cell Phone
The touch screen on my LG Dare keeps vibrating and activates different commands, calls, etc and sometimes it won't respond to actual touches
Hi, when a phones touch screen malfunctions, it means that the touch pad is damaged seriously and it needs to be replaced.
Mostly it is caused by dropping the phone on the flow, hitting it on something or even pressing the touch screen pad with the wrong instrument.(any sharp object).
You can take it to a here by store for a replacement.
NOTE: phone is very delicate needs to be handled by an experienced personnel.
Take care.
May 19, 2010 | LG Dare VX9700 Cell Phone
I have had my LG dare since July 2008. 2 days ago
you may have possibly damaged the screen from applying too much pressure, maybe not intentionally but from placing in pocket, sitting on it etc.... you can call verizon if you have the insurance and have the device replaced or check to see if it is under manufacture warranty. that specific problem exist in all touchscreen devices eventually.
Nov 16, 2009 | LG Dare VX9700 Cell Phone
Touch screen is not working
You can replace it. They run about 15 dollars from ebay and are pretty striaght forward. Here is a link on how to replace the touchscreen on the Ku990.
http://www.crackedlcdrepair.com/replace-the-lg-viewty-ku990-lcd-screen/343/
Sep 26, 2009 | LG KU990 Viewty
Garmin touchscreen
This was just suggested for the exact same problem with my StreetPilot 2620 and worked like a charm: (1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored. Thank you for rating this solution. Good luck and save you $250 for something else!
Jun 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
LG Dare VX9700  Cell Phone Logo
83 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
