Question about Maytag MED9600S Electric Dryer
Loud scraping sound
We just got a maytag epic Z but it makes a loud scraping noise when it's turned on....what is wrong?
  • 145 Answers
If it was put on a dolly from the back or dropped on the bottom the blower housing could be in contact with the drum as it goes around.
Posted on Apr 24, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Front load spin noise
Your rear bearing is going out. This is a long and arduous repair and should only be done by a qualified technician, expect to spend at least $600 or more.
May 28, 2012 | Maytag Washing Machines
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
May 19, 2010 | Washing Machines
Makes loud noises
Although there may not be any gas parts involve you should have gas technician work on the unit. Depending on the noise your hearing it could be a number of things, if its making a scraping noise it could be that your front drum glides are gone allowing the drum to ride on the frame of the door. glide part numbers are 306508. if the noise you hear sounds like a grating sound it could be that your blower wheel has something caught in it and is now rubbing on all of the fan blades on the blower.blower part number is 33002797. if you hear a loud banging noise you could have a rear bearing issue. both roller bearing part numbers are y303373.hope this helps
Oct 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Front Load Dryer
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
Jan 26, 2008 | Maytag MED9600S Electric Dryer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Maytag MED9600S Electric Dryer Logo
259 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
