I have a Maytag washer model# PAV2300AWW. When I start it, it agitates slowly and makes a loud noise. If I put it on the spin cycle it spins just fine. What could be the problem?
  • hecnlu Aug 02, 2010
    The solution was helpful. When it comes to replacing things like motors or transmissions, I draw the line. At that point, I consider a new appliance. I appreciate the help though.
  • 6,784 Answers
HI. Unfortunately this will be a transmission issue. If the agitator oscillates as design(right to left) with no grinding at the agitator assembly, this will confirm the local damage to the transmission. This is not a gear box, so you cannot individually replace the agitation gear, due to the fact that, the transmission housing is a sealed compartment. You will need to replace the entire transmission.
With that said; Double check to be sure that the origin of the noise is indeed coming from the lower/center section of the cabinet. Once you have confirmed that the noise is indeed coming form the transmission, have it replaced, asap.
Transmission part number will be 35-6615
Click here to access the service manual. Use this manual to help with the disassembling process and transmission extraction.
Posted on Jul 31, 2010
    OK. Well if its the motor or transmission (as the other gentleman suggested), it seems like more than I want to spend to repair it right now. Thanks for the information though!
  • Washing Mach... Master
  • 43,501 Answers
If you were complaining of a slow spin I would say you had a bad bearing...but...
because you are saying that the agitation is slow I believe you have a bad motor...the motor runs in one direction for the agitation and the other for the spin...
so I think that the motor has gone bad when running in the direction needed for the agitation...the spin direction works just fine...
when the motor goes bad it often will make a very loud noise also...
here is the motor for your machine...
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PAV2300AWW-%3d%3di1023733&PartID=1023733
heatman101
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
