Toshiba ct-90275 code for direct tv d10
I need a code so my Toshiba ct90275 remote will work on my direct tv receiver model d10. Hope you can help me. thanks
  • dverk May 20, 2008
    I have same remote Toshiba CT-90275 and can't get it to operate the Direct Tv receiver. The site that was referred to gave 4 digit codes, the original manual only has 3 digit codes. The "search" process you described isn't correct. To program this remote it requires the "recall" button be held as the 3 digit code is input. No red LCD flash or blink at all. Help does anybody know the Direct TV brand 3 digit code possibilities for this Toshiba remote?
  • Anonymous Nov 16, 2008
    I have the same problem, the Toshiba manual lists the code 059 for the
    samsung satellite receiver and the codes 077 and 090. Neither of these
    codes work for me but you may want to try them. If you find the
    correct code, please let me know.
The solution offered does not address the problem. The solution shows how to program a TV or component using the Directv remote, but the user wants to control the Directv receiver from a Toshiba remote. And who can blame him or her... Directv's remotes are horrible.
Posted on Jun 29, 2008
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a Fixya rating if you have been able to fix the problem, so that I can remove it from my work queue.
    Thank you.
I have a Toshiba 19CV100U TV and a Toshiba CT-90275 remote control. My problem is that the dash button doesn't work so I can't put in digital channels. How do I fix this?
If your Toshiba TV does not have digital conversion built in, you will have to install a converter box and separate remote.
I have no idea what a "dash button" is or controls.
Oct 17, 2014 | Televison & Video
Need remote code for DRC277
I found on my toshiba tv remote that the code for the rca was 039
some of the buttons were mixed up but its better than nothing.
Also remote has to be set to Aux. 2
Jan 20, 2009 | RCA DRC277 DVD Player
Remote
Hello. Here's your instructions:
Press the MENU key. Press the up/down arrows to get to Input Connfiguration. Press the right left/keys to change to CABLE, and then press enter. Then press the up/down arrows to get to Auto Ch Search. Press the right arrow or ENTER, and let the tv go through all the channels to add them - this make take a little time.
Hope this helps, please rate! :)
Oct 26, 2008 | Toshiba 32A50 32" TV
Toshiba CT-90275 3 digit code for Direct Tv R-16
Not really too sure about Direct TV. But give me some time, I have asked some other Experts here for their help. Hopefully one or two of them may have an answer..
Please do not rate this solution yet..
May 21, 2008 | Televison & Video
Toshiba Regza 32LV67U remote control code CT-90275
my lcd screen toshiba is broken, what can make??
Feb 23, 2008 | Televison & Video
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Televison & Video Logo
5,041 people viewed this question
Top Televison & Video Experts
