Question about Haier 3.5 cu. ft. Chest Freezer HNCM035E
We experienced a Sevrer Thunder Storm in our City on 07-23-2010 and as a result had a power outage for several hours. Once the power was restored, the Haier 3.5 cu ft chest freezer is no longer working and all the food has spoiled. The freezer was purchased in 2008.
    Novelist:
  • 155 Answers
Hello
Due to the heavy storm you experienced,and since the freezer was plugged during that period there might have been a negative effect from the storm on your freezer due to earth.All you need to do is to get a technician to check it out.
THANK YOU
Posted on Jul 28, 2010
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
How do you get compressor running after power outage?
Hello AnnArborMom, thank you for your inquiry!
I would recommend you adjusting the temperature to a lower setting to see if that would start your compressor to cool. If that is not successful I would contact a professional to come and properly diagnose your appliance. It could be that the power outage shorted the main control board or relay. I hope this is helpful. -Matt
Sep 07, 2014 | Frigidaire FGHF2366PF Gallery 22.6 Cu. Ft....
Power outage and fridge doesnt come back on when power is restored
First make sure there is power to the plug at the wall. If not check the breaker. If power at the plug, the power outage could have been associated with a power surge that killed your refrig.
Mar 21, 2014 | Whirlpool WRF560SMY 19.6 cu. ft. French...
Have power but not freezing, cannot hear motor, recently had power outage
Hello max ryan,
I understand that you had a power outage and now that power was restored, you have power inside the appliance but the freezer is not freezing and you can't hear the motor running. I would double check the breakers and make sure that they are on. You can also check the Temperature Control and make sure that it is not in the OFF position. If these solutions do not work, I would call the manufacturer for more help.
-Best Regards-
Jan 04, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Kenmore upright - wont defrost, runs continuously and wont freeze properly
well don't be surprised, these electronic fridges run on dc electronics also and are sensitive to power surges. is this the freezer because there's no thermostats just the limit control. use a surge protector on the outlet to protect the electronics. if your still having problems get the limit sensors changed first (if applicable). if you want to go the safe way, I'd consider buying a surge protector and connecting it to the power.you can e-mail me with any questions @ hvac.tech7872pr@gmail.com
Jun 14, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Power Outage?
johnny try to connect the fridge using a stabliser to the wall plug and make the control to the min coll and check if it is ok then the problem is of the connecting load to the wall plug
Jul 03, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier 3.5 cu. ft. Chest Freezer HNCM035E Logo
165 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
