Question about GE Electrical Supplies
How do i strip a roof
How do i replace a bad circuit breaker
  • 760 Answers
First I hope you have a main disconnect in your panel. If not, you really should have an electrician do it. Ok with power off, remove cover. It depends on what mfg the breaker is, but in most residintial areas, you simply unplug the breaker from the buss bar, then continue to raise it and then withdraw the breaker from the real clip that attached it to the panel. You must also loosen the screw terminal to remove wires.
Posted on Aug 12, 2010
2000 Isuzu Rodeo, how do I reset the circuit breaker for the power windows
a fuse is a circuit breaker
if the fuse for the power windows is ok the the problem is else where -- could be a relay that is faulty
Sep 10, 2016 | 2000 Isuzu Rodeo
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
Relay location for moon roof and power windows
These aren't relays or fuses. They are circuit breakers. About an inch long and quarter inch wide, with a metal case. The rarely go bad. I don't know exactly where yours is, but they are always in the dash fuse panel.
May 12, 2015 | 1999 Toyota Sienna
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
My coleman Mach Rv air conditioner with built in heat strip keeps tripping it's internal circuit breaker when running for any length of time. Just replaced heat strip with new one experienced same issue. I...
There should be an overload protection device in series with the low voltage wiring(t-stat wiring) Is it resting on the heat strip or too close to it? It is a saftey device to shut off the heat strips if the fan quits or a fire in the heat strip section. check that or by pass it, if it stays running then ur thermal protector is bad, couple bucks at the parts house.
Nov 06, 2010 | Coleman Mach III Air Conditioner
My sunroof is not able to be closed. It is in the pop up position. Is there a manual way to close it? eg no use of electricity?
there is no manual method. It sounds like a limit switch is not working. Can you hear the motor try to operate? If you push up on the back of the glass a little bit while hitting the switch, what happens.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
The sliding roof panel system consists of the following components:
  • RH circuit breaker
  • Timer module
  • Power window relay
  • Roof sliding panel switch (15B691)
  • Roof glass panel (50054)
  • Sliding roof panel motor (15790)
  • Halo moulding
  • Roof sliding panel headlining (519A02)
  • Roof sliding panel slide links (502M78)
  • Roof sliding panel housing (502C22)
  • Roof air deflector (500A26)
  • Center green diode strip
When the roof sliding panel switch is activated, a gear on the sliding roof panel motor drives a spline on the roof sliding panel housing. Within the roof sliding panel housing, the spline is connected to two sliding roof panel cables which cause the roof sliding panel slide links to slide and the roof glass panel to open or to close. The sliding roof panel cables and the spline are part of the roof sliding panel housing. Neither the sliding roof panel motor nor the roof sliding panel housing can be disassembled. If a malfunction is detected with either of these assemblies, the assembly must be replaced.
VISUAL INSPECTION CHART Mechanical Electrical
  • Sliding roof panel height adjustment
  • Sliding roof panel fore and aft adjustment
  • Blown fuse(s):
    • 30A PWR WDW
  • Damaged circuit breaker #1
  • Damaged wiring harness
  • Loose or corroded connections
  • Fuses.
  • Circuit breaker #2.
  • Power window relay.
  • Sliding roof panel motor.
  • Roof sliding panel switch.
  • Circuit.
  • GO to Pinpoint Test E1 .
  • Sliding Roof Panel Will Not Stop in Vent Position
Switch Removal
  1. Disconnect the battery ground cable (14301).
  1. Gently pry the overhead console from the headliner.
  1. Disconnect the sliding roof panel electrical connector from the overhead console.
  1. Disconnect the rear quarter window switch electrical connector from the overhead console, if equipped.
  1. Disconnect the map lamp electrical connector from the overhead console.
  1. Remove the overhead console.
  1. Remove the two roof sliding panel switch screws and the roof sliding panel switch (15B691).
Motor Removal
  1. Place the roof glass panel (50054) in the closed position.
  1. Remove the roof headlining (51916). Refer to Section 01-05 for the removal procedure.
  1. Remove the two sliding roof panel relays from their brackets.
  1. Disconnect the two sliding roof panel motor electrical connectors.
  1. Remove the two sliding roof panel motor screws and the sliding roof panel motor (15790
Jan 11, 2010 | 1997 Mercury Villager
30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Mar 05, 2009 | Weather King 10AJA2501AH Air Conditioner
Powercom BNT 1500AP quit working after power outage
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Dec 28, 2008 | Powercom (BNT-1500AP) UPS System
Power sun roof
It may be a circuit breaker.My windows and door locks stopped working,even after checking all fuses and replacing Main Driver side door switch! Found three circuit breakers that you can reset with a paper clip or small screwdriver. They were black with an aluminum cover on top. They don't come out easily,just insert the pin on each one.
Jul 27, 2008 | 1992 Pontiac Grand Prix
Electrical Supplies Logo
73 people viewed this question
Top GE Electrical Supplies Experts
Steve
Lawrence Oravetz
robert
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
