Question about Samsung Televison & Video
Short circuit on the "Y" sustain board
Do you know what would cause the "Y" sustain board to short circuit on a Samsung 50" plasma television(PS50C96HDX) that is only 2 1/2 years old?
A couple of days back the tv screen went black but there was still sound,the tv repair shop has said the Y Sustain board has a short circuit and will need to be replaced along with the upper and lower buffer boards...which is gonna cost quite alot to fix.
Any ideas what would cause it to short circuit when the television is not very old?
  • angie_t_hobd Dec 13, 2010
    Thanks for the reply...... I posted this question a couple of months ago and since then I contacted Samsung who took the TV in for repair....Only charging for labour costs(The parts were going to cost nearly £300 and labour was going to be £75) but after waiting 2 weeks for them to fix it when they said it would be done within 10 days, they then said it was going to take another month to get the parts....after complaining alot to them they decided to give me a new tv...which is better than the one I had.....So if anyone else has this same problem after warranty runs out contact the manufacturer you should hopefully at least get it repaired for a lot less than a repair shop.
  • 28 Answers
The problem is heat!!! If the tv has fans they should be checked for normal operation,although on the early samsung models there were none, and the problem is that the panel drive buffers are getting to hot due to inadequate cooling. This is most apperent when tv is mounted to close to the wall, also external fan blowing on the rear left side will dissapate the heat. It is a problem on early Samsung and Electrograph 42 " plasma models. Hope this helps.
Posted on Dec 12, 2010
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
Feb 01, 2015 | Samsung HPT5054 50-Inch Plasma HDTV
Samsung plasma 50" turns on and off by itself
Check the sustain boards for short. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 12, 2014 | Televison & Video
My L G 50" plasma makes a clicking noise when in H D mode
Short circuited component/s at its sustain board. Contact any service technician.
Electro help
Oct 06, 2014 | LG 50PX5D 50 in. Plasma HDTV
I have a samsung ps50c7000 plasma tv that is powering on/off every 5/6 minutes.
If it powers On/OFF; repeatedly, surely there is a short circuited board inside it. Most likely, it can be Y-Sustain drive board. But, make it sure is somewhat skilled work, that a normal user can't do.
I advice you to contact any service technician in this case. The best thing is to contact the authorized service center for Samsung.
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 26, 2014 | Samsung 50 in. Plasma TV
How to take the samsung pl50 video cam of standby
There should be any short circuit to any of the circuit boards inside it. Check and locate the board first. Being a plasma display, the circuit will be quiet complicated to an experienced person to work on. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 09, 2013 | HP PL5060N 50 in. Plasma HDTV
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
I have a panasonic 50" plasma that turns off about
It can be bad power supply or shorted circuits in the sustain boards which will cause the power supply to go into shutdown mode. You need to open it up and inspect those board for bad caps, blown fuses or burnt parts, Most failure in the PLASMA TV are due to bad power supply, failed Z-sustain Y-sustain boards.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Dec 14, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Need a flow chart or schematic for samsung hp-s5033 we change three pannels set still wont power on.
WHEN YOU SAY SUSTAIN BOARD YOU MEAN Y BORD AND WHEN YOU SAY BALLAST BOARD YOU MEAN UPPER Y BUFFER BOARD ONE RULE WHEN THE Y BOARD OR Y BUFFER BOARD ARE DEFECTIVE YOU MUST REPLACE THEM AT THE SAME TIME AS A SET ,A NOTHER POSSIBILTY BUT VERY RARE X BOARD COULD BE SHORT OR WORST OF ALL THE PANEL BUT 90 PERCENY OF THE TIME WHEN YOU REPLACE THE Y BORD WITH THE 2 BUFFER BOARDS YOU SOLVE THE PROBLEM HPOE THIS WILL HELP
Jul 30, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
LG 50PX2DC 50
The y sustain board and the z sustain board and control board have to be replaced.
Nov 10, 2008 | LG 50PX2DC 50 in. Plasma Television
Televison & Video Logo
886 people viewed this question
Jerry Greenberg
Jerry Greenberg
