Question about Fisher and Paykel DEGX1 Electric Dryer
When the drum spins, there is a loud noise.
Someone fixed this for me before, but that person is not around and I am trying to do it myself. As I recall, there was a belt towards the bottom front and it was not in alignment. The sound is the same, so I am thinking the issue may be the same. I am trying to remove the outside panels, so I can see inside the front of the machine. I'm having trouble just getting the front panel off the machine. Can someone help me please. thank you.
  • 478 Answers
There are two little plastic pieces on the front that hide the scerws, they are about the size of a pen. Its been a couple of years since I fixed one but I seem to remember them at the top. Good luck.
Posted on Jul 29, 2010
Kenmore 90 series makes a loud noise during spinning and it looks like the basket is loose
On most Kenmore or whirlpool dryers, you have two wheels that have rubber around them. They look like wheels off of rollerblade skates. They simply bolt on to the back, but you have to usually put a large piece of wood to act as a fulcrum as you support the weight of the drum and change out the two wheels. Check with searspartsdirect.com for the parts prior to taking the dryer apart. I had a machine that sounded like tennis shoes were rolling around the drum and fixed the issue by simply replacing these two wheels.
Good Luck
Jul 23, 2014 | Kenmore Washing Machines
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Loading clicking noise on spin
Could be excuse me ..Bra wire in drum stick your head in and look, if so best way to remove is take out heater to fix only if you are confident in repair..Good luck
Oct 02, 2009 | Washing Machines
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Dec 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Mar 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Loud Noise - Spin Cycle
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Fisher and Paykel DEGX1 Electric Dryer Logo
110 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
