Question about JVC AV-32020 32" TV
Buzzzing sound When i cut the tv on it makes a loud buzzing sound! I took the back off and it sounds like its coming from a little transformer looking thing!
  • stebo12 Apr 26, 2008
    how do u do a continuity test?
  • 934 Answers
That's called your secondary and it a feedback you're hearing probably because the HOT is shorted... Unplg the unit and do a continuity test on the horizontal output transistor - in particular E to B and if you get infinity that's your trouble.
Bill
Posted on Apr 26, 2008
  • William Rayburn
    William Rayburn Apr 27, 2008
    Using a dmm (digital multi-meter) or analog multi-meter set it for continuity. That meand when both probes are touching you get an infinity reading. Then touch each probe, one to the "E"lectrode and one to the "B"ase of the HOT and if it reads infinity BINGO bad Ic...
    Bill
Microwave makes a loud buzzing noise
The buzzing sound could be from loose laminations on the high voltage transformer, or from loose mounting screws for the transformer. This requires investigation by a qualified technician as there are lethal voltages associated with the transformer. It could also be from a loose cover. First check that all the cover screws are tight.
Mar 21, 2014 | Electrolux Microwave Ovens
TV making loud buzzing sound
More sets than you might imagine have this kind of problem---I a regular TV it is usually a transformer that is vibrating hard enough to make the sound---the higher pitched sound is just that--a sound.
If this is a direct view(means not a flatscreen and has a Glass Picture tube it will be either the high voltage transformer or one of several smaller transformers.
This can usually be fixed---seen a few so loud the cats in the house run away.
Let me know model number of set for more information.
On chance it has the high voltage transformer I attach a photo of what that looks like.
May 23, 2012 | Zenith Televison & Video
A loud buzzing is coming from the back of my sanyo ds 25390 tv. picture and regular sound is fine
If it is a high pitched whine or buzz it is likely a transformer vibrating so hard it is making the noise.
There are ways to try to deal with this issue but the set has to be opened and probed to locate where it is coming from--
for example with back off and set on a plastic rod can be used to touch areas and exert slight pressure until the sound changes or goes away--then either replace the part or I have used hot glue etc to stop it.
You first have to locate the source of the issue:
find where it is coming from.
Mar 24, 2012 | Televison & Video
Picture and sound go after a while will come back after switching to standby Or the old fashion Bang on the top. Also a Loud buzzing sound in Standby.
U have tools like a soldering iron,a roll solders,also can u do basic soldering?Yes.This tv have cold solders joints in the(CRT-Tv tube) video board connections pins socket that connected to the(CRT-Tv tube).The tv loud buzzing sound is comming from the FBT-the flyback transformer,that is a big black block of plastic with a red wire with a cap that hook to the(CRT-Tv tube).Resolders both the FBT and the video board CRT socket holes connections.Will solved these 2 problems.
Dec 03, 2010 | Toshiba Televison & Video
Quasar 1989 tv makes a buzzing motor sound
Hi and welcome to FixYa,
Initially, if you have confirmed that the source of the buzzing sound is from inside the TV, then that would indicate a component about to fail or would need attention. Let us try process of elimination:
  • tuner - most unlikely, the tuner is responsible for selecting the channel. No component/part of the tuner could make such a mechanical buzzing sound;
  • speaker(s) - most unlikely, the speaker could have a buzz but generally would not affect the video nor cause snow (weak TV signals);
  • transformer - a strong possibility although without knowing the exact model, at most generic ideas; power transformer, flyback transformer, horizontal drive transformer (unlikely);
  • arcing - another strong possibility. This could be caused by damp, dusty surroundings of the components especially at the FBT area. Another area that could have adverse effect when dusty/damp would be the anode cap.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Televison & Video
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Loud sound from tv
It could be the inverter board going bad. The inverter board is what makes the back lights come on and has transformers on it that have high voltage. any time you have a noise like a buzzing or arcing you should have it checked
Mar 25, 2008 | Protron PLTV-32 Television
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Buzzing
The noise is caused by dust on one of the toroidal transformers(usually a round looking thing with wire wound around it). Go to the back of your television and try and pinpoint were the sound is coming from. Turn your television off and blow it out with compressed air if it is close to air vents in the television. If you cant see it you might have to open your television back panel.
Nov 23, 2006 | Panasonic TH-37PE30 37 in. Plasma...
JVC AV-32020 32" TV Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
