Question about GE GSS20IEP Side by Side Refrigerator
GE side by side keeps frosting up and fridge is not very cold
I have a GE side by side refrigerator (not sure of the model…not in front of it right now) that is not working properly. The freezer side keeps frosting up along the back wall and the fridge side is not very cold. I have the temperature settings on 5 for the freezer and 6 for the fridge. When I put them both at a 9 (the coldest setting) the freezer side frosted up very fast and the fridge side did not cool down any. I unplugged the unit and let it defrost and wiped it down, but when I turned it back on there was no change. Also the ice machine is not making any ice. I have looked through the owner’s manual and it is not helpful at all. I am looking for any advice in hopes that I can resolve this issue without having someone come out, as I do not think there is anything major wrong with it.
Sincerely,
C
  • 311 Answers
It sounds like you have a defrost system problem. most commonly its your defrost heater on most GE ref. It can be located by removing the back panel of the freezer. If you remove the heater it can be tested for continuity at any parts distributor. I would also look for the quarter sized thermostat mounted at the top of the coils to see if it looks "popped" at the top. If it is then replace the thermostat. Hope this helps MJ
Posted on Jul 28, 2010
GE fridge freezer froze up. Side by side doors. Need to know how to defrost freezer and keep the refrigerator side running. Model GSH25JFXNCC.
To get frost off the inside or out of the coil?
I would see if you have different controls for the freezer side and fridge side. If so turn the freezer off. If you can see the frozen coil use a hair dryer on it to speed the process. Usually the fridge side just steals cold air from the freezer side however.
If you're talking about frost on the inside, take all the food out and put in ice chest. Leave freezer door open, point a fan into it, use a hair dryer to speed up the process.
Some models have a drain hole in the bottom that goes to a short hose. You can add hose to that to run outside. If not you'll need some beach towels.
Mar 11, 2018 | GE Refrigerators
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and Freezer are Warm Ice is still being made
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Apr 17, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a GE GSS22JFPAWW Side by Side refrigerator. The coils keep freezing & so my fridge & freezer won't keep cold
If it keeps frosting up, there's a reason. This is a self-defrosting unit. The most common problem on that model is the defrost heater/harness assembly. It is part number WR51X10101. It can be checked easily with an ohm meter. This is quite possibly what ails your unit.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
1,083 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
