Question about Konica Minolta magicolor 2300DL Laser Printer
Black bullets down left side of paper
Hi Folks.
When I print a document, I get black bullets (dots) down the left side of the paper at the margin. I've cleaned the rollers, but it doesn't go away. Is it caused by the drum or toner cartridges?
Thanks
KC
    Champion:
  • 214 Answers
Inspect the pc drum, if there is no dots, then its ok, also inspect fusing unit rollers and transfer belt for dots and clean laser glass.
Posted on Jul 02, 2008
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
All printing on my Dell 3010 CN does not print about 2cm all the way down the right side of A4 paper this includes all colours and black
check your print settings and margin settings on the document. this should work ..
Thanks If this helps then kindly rate me.
Oct 30, 2010 | Dell 3010cn Laser Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
it sounds like the CYAN toner cartridge is leaking.
Jan 22, 2009 | Office Equipment & Supplies
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Dots on the left side margin
This problem comes from drum cartridge, you may try:
1) take out drum cartidge open drum cover clean the surface at leftside(using soft brush) and check drum surface at leftside, there is damage if you see the color surface appear a broken-ring at leftside(the color changed), you have to change new drum cartridge,
2) sometimes cause cartidge clean brush dirty can not do well cleaning job, just clean this parts at leftside well then turning drum a little there is no toner appear at surfac leftside if ok.
Dec 21, 2008 | Brother HL 2140 Laser Printer
Black dot in left margin.
If the black dots were not present with the old cartridge, then one can only suspect the new cartridge at fault. This rarely happens but it do happen. Chances are that there is a defect on the drum inside the new cartridge. You can visually check for this imperfection by removing the cartridge and sliding the protective cover to partially expose the drum (not in direct sunlight as they are light sensitive). There is a white gear at the side that you can manually rotate ( a bit stiff) to check for the possible fault. you can approximate the possible location by aligning a printed paper with the series of dots against the drum to give you an idea where to concentrate on.
Should this be the case, it is possible for you to return the new cartridge for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Samsung ML 2010 Laser Printer
Landscape print gives dots or lines in the upper margin
unplog your printer.clean your printhead of the printer by a tissue paper.
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
349 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
