Question about Sony Walkman NWZ-B135 MP3 Player
There is a white line running accross my screen and my walkman is not responding at all, any ideas ???
I have an LG 42'' PDP42V60001 plasma TV it has a white line running from top to bottom covering around a 1/4 of the screen, it moves accross the screen and the rest of the screen is black. Intermittently...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 17, 2017 | LG Televison & Video
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
White lines in my laptop's screen
its your screen problem of your laptop pls change it,
Apr 15, 2010 | Dell Inspiron 6400 Notebook
My picture shrinks
resolder the vertical deflection i.c. also replace elecrolytic capacitor in the vertical circuit.
Sep 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
White line of death
Press "volume -" button while u connect it to pc and download the firmware upgrade from sony site....run it and u're done....
Jun 30, 2009 | Sony Walkman NWZ-B135 MP3 Player
Sony walkman 4GB NO RESPOND/FROZE with screen saying"WALKMAN"
there is a reset button hold it down for 10-30 seconds....prolly what you are doing is not allowing the comp to disconnect thru icon 1st before you dissconnect the mp3 player.....btw if you do this to often the computer can start acting up
Dec 02, 2008 | Sony Walkman NWZ-S616F MP3 Player
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Sony Walkman NWZ-B135  MP3 Player Logo
315 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
