Question about Linksys WUSB54GC 802.11g/b Wireless Adapter
Hasa yellow excla. mark at and says limited or no
I have a yellow excla. mark at bottom of screen, and says limited or no connectivity. when you open up the linksys network monitor it says u r connected to access point but the internet cannot be found.I have tried reentering the passphrase but did not work. Uninstalled and then reinstalled drivers nothing seems to work AAAAAAAarrrrrrrrrrrrrrrrggggggggggghhhhhhhhhhhhhh!!!!!!
    Scholar:
  • 85 Answers
If you have a Linksys router that is connected to your modem then you might want to do the following:
It could be that the Security Key is not correct. Make sure that the right security key is being used.
If you have already configured your router with the security key then to the following.
Open up an Internet Explorer Browswer page on a computer that is connected on the network already. Type in the address bar 192.168.1.1 and hit enter.
A box should pop up and request that you log in. Place in your password that you had created. If you have never created a password then leave the username blank and type in the password box admin in lower case.
Click on the Wireless Tab
Click on the Sub tab under wireless then Wireless Security. In this window you will find the security key.. Write the correct key down not the passphrase.
Hope that helps.
Posted on Jul 28, 2010
Yellow exclamation mark in network tray
Ur connection is Limited . go to open network and sharing centre and click Local area conection selcet properties and selcet TCP/IP v4 ang give corect ip address
May 14, 2014 | Lenovo X201 520M 2GB/320 BT F C W7-32 -...
Limited or no connectivity
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
if still no luck
i
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus
if you see see something running that should not be select end now or you might even uninstall that certain program and possibly some unnecssary programs trying to access your internet connection at the same time
hope this helps
Jul 07, 2012 | Computers & Internet
Windows could not connect to the system
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
hope it helps
Jun 02, 2012 | Acer EXTENSA 5230E COMPATIBLE LAPTOP LCD...
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
Yellow marks on ethernet controller
Download the LAN driver for your model computer if it is a built-in network adapter.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 19, 2011 | ASUS PCI-L3C920 Network Adapter
NET WORK CONNECTIVITY PROBLEM " LIMITED OR NO NETWORK"
get rid of your D Link router and get a linksys or netgear.
D Link are rubbish and are not worth the hassle.
Apr 13, 2009 | Computers & Internet
Limited or no connection!
http://www.snapfiles.com/get/winsockxpfix.html
Try running that program and if that does not fix your problem then you should goto your network connections page inside of the control panel and right clickon your Wireless Connection and go to properties, Once there click on Internet Protocol TCP/IP to highlight it and then click properties and make sure everyhting is set to obtain automatically.
Apr 07, 2009 | Acer Aspire One PC Notebook
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How do i plug a game conlone to a direct tv box?
skate,
are you reffering to a game console connecting direct to a TV screen?
1st try to check if your TV screen have a terminal jack indicating "A/V INPUT" A/V stands for Audio/video. if the screen doesn't have this, you'll be needing A/V to RF converter
2nd if your screen does have a terminal jack indicating A/V INPUT the next step you need to do is: check your game consul cable it should have a 3 RCA cable having RED/WHITE and yellow marking.
RED and WHITE cable marking stands for "AUDIO"
YELLOW cable marking stannds for "VIDEO"
connect this cable to A/V input of your screen following the color code ( yellow to yello/ red to red/ white to white) then from the screen press a button indicating "A/V" or "INPUT"
cheers,
mark
Jan 29, 2009 | Toshiba 36A50 36" TV
Linksys WUSB54GC 802.11g/b Wireless Adapter Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
