Question about Epson PictureMate InkJet Photo Printer
My epson picture mate prints red tinted pictures eventhough I just changed the cartridge
kcmetal9901
  • 102 Answers
SOURCE: Non-Epson cartridge
Yes this is a common problem. Go to Epsons web site and download any updates and this will usaully fix it. If not reinstall your printer and then again check for updates.
Posted on Nov 01, 2008
gwbm
  • 353 Answers
SOURCE: The new ink cartridge is not dispensing its color.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Posted on Feb 28, 2009
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
  • 26 Answers
SOURCE: Epson PX800FW prints coming out too red
Hi dotokpa,
There could be a number of reasons for this. The first is that your monitor may not be calibrated for print, so the image you see on your monitor is not actually how it will look when printed. http://epaperpress.com/monitorcal/ is a good website that will explain monitor calibration more in depth and will offer some free programs to calibrate your display.
It may also be that, since your printer is ink cartridge based, that you are running low in ink in some of the color cartridges so I would recommend checking that as well and replacing them if necessary.
Lastly, if you are still having problems you may need to adjust your printer settings, so when you go to print, under advanced tabs, and colour management you may be able to adjust the red, or darkness settings.
Hope this helps and please take a second to rate!
Posted on Mar 20, 2009
gwbm
  • 353 Answers
SOURCE: Epson DX7400 only printing Blue + Black
I'm sorry you have received no response on this , it's probably because you have posted it in the C86 printer group rather than the DX7400 group. I presume you have now solved this problem. If not, please re-open it (in the DX7400 group) for help.
Posted on Mar 28, 2009
Epson Stylus SX445W printing pictures with a red tint
Dear Kate,
please run the Epson maintenance software and check your printer cartridge.
i think printer head cleaning is the solution.
please run 1 or 2 cleaning cycles and give a try again.
if problem still there its time to go to technician.
regards,
nuwan.
Jan 10, 2014 | Epson Stylus Sx445w Inkjet Print Scan 5760...
I have an Epson Picture Mate Charm Compact photo Style C11CA56203-N. The pictures are coming out yellow and I've tried 3 different brand new ink cartridges, is there a way to fix?
Hi!
Did you run a Head Cleaning Cycle after changing the ink cartridges? Run at least Three head cleaning cycle to clean the nozzles of your printer.
Hope this helps...
Dec 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
When we print a coloured picture, dark colours are orangy red. Can we adjust anything to solve this problem?
If there are no issues with the head it is possible to correct the tint inthe printer. Open printer properties and select the tint settings.
make a test print after you have set and see if there is any change.
If no there can be issues with the head or the ink colours.
Sep 06, 2010 | Epson Stylus Photo R300 InkJet Printer
My pictures come out really green and have thin stripes across the picture. What do I do?
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 09, 2010 | Epson PictureMate (C11C556001) InkJet...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 22, 2010 | Epson R1900 Printer
My pictures are coming out rosey color looking instead of bright, I've cleaned the heads, and changed the cartridge and still don't get good pictures, help, sorry, I have a epson picture mate personal...
try to set the resolution of your epson, to picture quality or something like that.also you have to identify if the picture you are printing is same or big as the papar you are using, its possible that is in the picture it self.hope it help, :)
Oct 04, 2009 | Epson PictureMate Photo Printer
Hi dotokpa,
Mar 20, 2009 | Epson Office Equipment & Supplies
Non-Epson cartridge
Aug 26, 2008 | Epson PictureMate (C11C556001) InkJet...
Green Tint Over Entire Printed Picture
I had a very similar problem and found out that the problem was the quality of paper I was using. Remember, a photo printer is expecting high quality results. Cheap, low quality paper will not accept the ink as well as higher quality paper. I can't guarantee this will solve your problem but I have not had any green tints since switching to a higher quality photo paper.
Jun 27, 2008 | HP Photosmart 8150 InkJet Printer
Epson PictureMate InkJet Photo Printer Logo
136 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
