Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Light comes on - but no steam - used only 4 times - but last use was a few months ago -
  • Euro-Pro Master
  • 43,501 Answers
Rde
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
Tip
Shark Steam Pocket Mop Cleaning Problems
After watching Shark Steam Pocket Mop from the vantage point of Fixya.com for a few months and seeing the many problems that people were having with the Shark Steam Mop streaking their floors and especially hardwood or laminate flooring I decided to do some research and reading about this problem.
What I found was very interesting.
Many people are blaming the steam mop for their problems, when in fact the problem is just coming to light because of the use of the steam mop. It seems that if other cleaners have been used on the floors they leave behind a residue. Then you come along with this mop that produces a heated steam type cleaning and you start to take this residue off of the floors. This then leaves the flooring blotchy or streaking.
So now what do you do with you floors when you get this mop and what will cure your streaking, blotchy floors? There are a couple of ways....
First way is to just keep on using the mop. Many people report that their persistence has paid off and that after a few uses the shine comes back to their floor as the old scum and residue is more completely removed.
The second way is to use a vinegar and water solution to manually clean the flooring before using the mop. This takes a bit more elbow grease, but will get the floor looking really sharp much quicker. Here is a site that tells about that.
So if you are having a heart attack because your mop seems to be making things worse instead of better then don't give up too quickly!! Use it a few times first... it has a 1 year warranty. Or get on your knees with that pail of vinegar water and get the old gunk from all those other cleaners off of your floor first.
heatman101
Here are some other related tips to check out....
http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
http://www.fixya.com/support/r6896271-find_shark_parts_accessories
on Nov 07, 2010 | Vacuums
I own the shark steam mop S3501CO the light comes on the tank gets warm but no steam comes out
I posted this solution explaining how to clean the heater core.
http://youtu.be/S4NglGXVv50
Based on what I found when I disassembled my S3501 it would be very hard to clear heavy mineral deposits by just squirting CLR or vinegar soak.
Dec 11, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Very little water comes out when handle compressed but no steam. what do I do? Machine is only about 6 months old and has been used maybe 4 or 5 times.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Nov 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I purchased a Euro-Pro Steamer Mop 9 months ago and the Mop had just quit steaming. The green light is on and it makes a steaming sound but it is not getting hot and does not shoot out any steam like it...
Yeah, element is bad...
heatman101
Aug 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
HEATS UP BUT NO STEAM?
heatman101
n
Jul 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a bissel pro heat carpet cleaner that doesn't spray cleaner solution, everything else works, but I don't know whether it's the pump or the heat unit.I'm assuming that the pump unit must be bad since...
If you still have spray through the attachments then its the heating element. If not and your sure the belts are good ( if there intact but are a year or more old they need to be replaced ) then its probably the pump
Jun 27, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Scunci SS 1000
The steps to correct it: The thumb trigger and the sliding brass valve clog up and don't move. So if you use it and press the thumb trigger and no steam comes out, it's probably clogged.
Wait until it cools down. Empty the unit.
1.) unscrew any attachments and you will see where they screw in at the end, two small philips head screws on the end. remove them. The red rounded piece at the end will come off.
2.) now on the top, unscrew the water stopper top where you poor water in.
3.) Now below that is a round rubber piece that surrounds the threaded part where the stopper top screws on to. Grab it with your fingers and lift it up on the sides to remove it.
4.) now underneath here you can see two screws. Remove them.
5.) now grab the whole top piece that is "black" and pull upward to remove it. you may want to start at the front and work it off. It has a few snaps that will release when pulled. I have done this a few times so dont be afraid to pull this piece off.
6.) now you will see the valve assembly. Take a small hammer and tap on the small rounded "brass" nub that is sticking out of the "trigger side" of the valve. To know if it has released, I usually place my lips around the end that the steam comes out of and blow while pressing in on the little brass nub on the other side. I do this until that nub moves freely and I can hear the air escape out the top from my blowing on it. Sounds funny but it works. If not free, tap it harder, a few more times, until it is free. It will free up eventually. It gets stuck from time to time but this will get you back in business fairly quickly.
7.) move the nub a few times to ensure smooth movement.
Re-assembly
1.) The black plastic top will snap into place. Just line up the trigger spring with the red nub and snap the whole black piece back into place.
2.) place the two screws back in.
3.) The rubber protector ring is tricky. You will see the underside has a rubber edge that snaps in place. Work it around as best as possible and i usually use a screw driver to push the last little bit into place.
4.) place the red circular end cap on and the two screws that go with it.
you are all done. Once you do this a few times, you will become a pro OR as the above poster said, use distilled water.
Oct 08, 2008 | Scunci 52000 Handheld Steam Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
85 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
