Question about Maytag MSD2756G Side by Side Refrigerator
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to the refrigerator being cut off. My kitchen is starting to smell like mildew from the water leaking onto the floor. Please help. Thanks.
  • 311 Answers
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Posted on Jul 28, 2010
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice in the freezer side bottom of my side by side Maytag.
You are having either a defrost problem combined with the defrost drain being frozen over. Need to unplug and remove the rear panel in back of freezer to examine exactly what is happening. Some models like yours have electronic vents that cole if the control becomes defective. . The other possibilities ar the
Adaptive Defrost part number 61005988
The defrost heater with defrost thermostat part number 61006199
Visit our site or click on your model number or part number. I will be here to assist you in your repair, Thanks Sea Breeze
Click Here=> PART NUMBER AND MODEL SEARCH FEATURE
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag refrigerator
It may not be a water problem, it may be an air leak.
If there is something that is keeping the door from total closing, ice will build up from moisture.
check the gasket around the freezer door, or see if there is something that is keeping it from closeing completely.
Jun 02, 2008 | Maytag Refrigerators
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
704 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
