Question about Kohler Forte Two Handle Centerset Lavatory Faucet with Sculpted Lever Handl
Water leaks around the hot water handle when I turn on the water.
The water runs into the bathroom sink and no water is detected under the sink.
    Scholar:
  • 122 Answers
What valve do you have. most likely you will need to replace the cartridges
Posted on Aug 09, 2010
How can I fix a bathroom sink faucet?
THE LINE MAY BE CRIPPED. TIGHTEN THE NUT OR REPLACE THE NUT IF IT WILL NOT TIGHTEN. YOU MAY NEED A LONGER WATER LINE TO GET AROUND THE BUMP.
Oct 04, 2014 | Delta Plumbing
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Leaking hot water seal
leaking around handle?Turn water off under sink.remove handle,cover plate,unscrew valve stem assembly,and turn the two pieces apart to expose o ring,and replace
Jan 27, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
My waltec bathroom sink was leaking now that i messed with it ,its running by itself how do i fix this problem
It would help to know where is was leaking and what you "messed with"?
But in general, the idea is to replace the washers.
To do that, first turn off the water under the sink.
Then you first remove the handle on the leaking side.
There is often a small metal or plastic cover over a phillips screw.
Then remove the metal cap around the handle stem by unthreading or lifting up.
Then you can remove the valve by turning it as if to make the water go on.
It will have a washer on the bottom, held on with a screw.
Remove the screw, get a new washer, and then replace.
http://www.moen.com/shared/pdf/instruction_sheets/ins1923a.pdf
Dec 20, 2010 | Moen Kingsley Two Handle Bathroom Sink...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
Kohler Forte Two Handle Centerset Lavatory Faucet with Sculpted Lever Handl Logo
350 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
