Question about Garden
Starter Rope on Snapper Lawnmower no longer seemed to want to pull the crank. Took off the part with the rope and see that the rope is OK and that the automatic rewind of the rope is OK. What doesn't look right is the part that would fit into the crank has no way of interlocking with the crank to turn it. Not having seen it before it was broken it does not look broken to me. Can't tell what kind of engine it is. Only can supply Snapper serial # I see on the deck of the lawn mower.
  • 10,319 Answers
The inside of the drum or wheel you might call it were the rope is attached to has centrifical arms with pads on them
As you pull on the rope to start it the arms move outward to apply pressure the the engines clutch plate so it will spin to start.
The pads are simply worn and need to be replaced
Posted on Jul 28, 2010
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
Starter rope on push lawnmower pulled out too far and how do i get it to go back
if its not pulling rope back in then theres a good chance the recoil spring has broken!!
Sep 06, 2014 | Garden
How to replace starter rope in lawn mower
First assemble the following: Pliers, large vice grips, 'c' clamp or a bench mounted vise and new rope. Remove therecoil housing from top of engine. Turn it over, find the end of the broken rope and on pull it until it is fully extended but do not remove yet. While holding the rope extended place clamp device on the rope housing clamping the spool and housing. Be careful not to put too much pressure on the housing, just enough to hold the two pieces. Carefully remove old rope and thread the new rope through the small hole in the housing and into the slot in the pulley. Tie that end of rope into a knot to prevent rope from coming out. While holding other end of rope, carefully remove the clamp from the housing and slowly let the rope rewind into the housing. Replace rope housing onto top of motor. HOW TO Replace Broken Lawnmower Pull Cord
Sep 01, 2014 | Garden
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
Turn the key and just get a whirring sound. Is it the solenoid? What can I do?
sounds like the gear broke on the starter and lock up the flywheel take off the little cover over the flywheel and you will see it you can buy the gear for about 10 bucks
Apr 21, 2012 | Snapper Garden
Starter pull rope broke. how do i replace?
Should be 3-4 bolts right on top of the pull starterhousing, take them off to replace string
Nov 09, 2009 | Garden
How to replace the pull cord on a Scotts lawnmower SP6211 Roger
pull the starter housing off, take out the old rope, rotate the starter counter clock wise 5 to 6 times were the to holes line up stick a screw driver throw the holes to hold it in place. feed the same ty-ip rope from out side in throw then tie off. your going to need about 6 to 7 feet. let the pulley pull the rope in
Oct 13, 2009 | Garden
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
