Question about GPX MW3837 MP3 Player
Trying to delete files
When i try to delete the music files they tell me that the directory is not empty what does that mean and how do i delete them anyways?
  • 8,596 Answers
Use Windows Media Player 9 or 10
Posted on Jun 20, 2008
My Music folder suddenly deleted all the files in it, but the folder won't delete because it says it's not empty; however, it won't let me open it either. It keeps popping up an Error code 0x80070091: The...
You probably have a disk-drive with some "bad" sectors.
So, when you try to read the sectors that contain the directory for the 'My Music' folder,
that sector cannot be read, and thus Windows reports an "empty" folder.
It's probable that your disk-drive is about to _completely_ fail, not just _partially_.
Make a backup of what files & folders that _can_ be read.
Dec 11, 2010 | Western Digital WD Passport 250GB Portable...
My itunes wont let me open it its saying unkown error has occurred 13010
Hi crag81,
I understand you are receiving error 13010 when trying to open iTunes. If you are using iTunes 8.0.2. I suggest you upgrade (but if you cannot): Remove the Genius database In the "Finder" go to the /username/Music/iTunes/ directory and delete the "iTunes Library Genius.itdb" file. This should allow the program to launch again. This file will be recreated upon first use of the "Genius" feature.
If you are windows, Remove the Genius database In the "My Documents" go to the /My Documents/Music/iTunes/ directory and delete the "iTunes Library Genius.itdb" file. This should allow the program to launch again. This file will be recreated upon first use of the "Genius" feature.
NOTE: If your using Vista or WIN 7 go to /yourusername/Music (one directory back from My Music (from above =)),
Nov 13, 2010 | Apple iTunes
I have downloaded I tunes & its telling me that I tunes is locked
Sounds like your permissions are a bit messed up. Try this:
In the Finder, use the Go menu and choose Utilities. Look for Disk Utility and open it up. Click on your hard drive on the left and click the Repair Permissions button on the right. After it completes, restart your computer and try opening iTunes again.
Sep 19, 2010 | Computers & Internet
Error 0x80070091 the directory is not empty
There is most likely a hidden or read only file located in this dir. Have you tried to view the hidden files?
Jun 11, 2009 | Microsoft Windows Vista Home Premium for...
Suddenly unable to view music files on the computer with GPX MW38
The mp3 player was on MTP mode; it needed to be switched to USB mode, which can be done by holding the M button for a few seconds while the player is plugged in to the computer.
Jun 05, 2009 | GPX MW3826 MP3 Player
Suddenly a corrupt file/lost directory/can't delete
well actually you can't just remove it alone just like that..since it is corrupted..you ll have to take back up n format your MP3 player !! that ll make your much safe and better..I suggest that you should format it as soon as possible..else it may corrupt other files..
May 25, 2009 | Audio Players & Recorders
Ghost librarary: deleted files still shown on media directory
The problem is that the Archos stores library information separately from the actual files on the device and the library must be updated whenever the files are changed.
To manually update your library:  From the main screen on your Archos 605, choose the Settings menu from the bottom right corner and select "System".
If there is an "Update ARCLibrary" button available, then click that button and see if it updates your device.
If the button is not there, or does not work, then try temporarily switching the "UBS Preference" setting to 'Windows Media Device" and closing the Settings screen.  This should invoke the library update.  Once updated, you can switch back to PC Hard Drive Mode.
Mar 11, 2009 | Archos 605 WiFi Digital Media Player
10 to 20 percent music files-(message)"unable to copy file or directory"
go to your folder with the files you want to share, open the folder select all of the music files copy them. Open up your brothers flash drive then paste them onto it.
If you have made a shortcut to these files on your desktop then copying them it maybe trying to copy the shortcuts and it won't work.
Another thing to check is that the music files are in the right format for the flash drive.
Oct 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HP IPAQ POCKET PC
1st approach (Quick one!)
1. Soft reset your device
2. make a backup copy of the folder \SD-MMCard\MSMETADATA if exists.
3. delete the folder \SD-MMCard\MSMETADATA.
4. Soft reset your device once again.
2nd approach (Long one!)
If 1st approach did not work, restore the MSMETADATA folder and try the following:
Step Zero: BACKUP
- Make a full backup of your device (including storage cards). If you don't like to do a full backup keep at least a backup of all files and folders we are going to delete as indicated below:
Step One
-In the main device directory delete the file WMPInfo.xml
-Delete the \Application Data\Microsoft\Media Player\ directory and all of
the files in it including the WMDRM folder.
-Delete the \Music folder
Step Two
-Go to your SD card main directory and delete the file WMPInfo.xml
-Delete the folder \SD-MMCard\MSMETADATA
-Delete the folder \SD-MMCard\WMDRM
-Delete the folder \SD-MMCard\Music
Step Three
-Repeat step two for any other storage cards.
Step Four
-Refresh devices in WMP and the storages card should show up in the left tab
and in the sync window you can click "Next Device"
Hope this helps...
Feb 25, 2008 | HP iPAQ rx1950 Pocket PC
Empty folder
There may be possible reasons why your Sansa E250 would display an message on the LCD even when you've downloaded files to it: (1) The music file type is not supported by the player. Sansa players support only MP3 and WMA files. To determine what file type your have, right click on the file type and it should display the "properties" dialog box. Check if it is MP3 or WMA. For example, iTunes music files will not work with the player, nor will WAV or MIDI files. (2) Your music files are supported but the bit rate is not within the range that the player supports. Sansa players support MP3 files up to 128 KBPS and WMA files up to 64 KBPS. You may need to use a 3rd party music file editor to convert the files to a supported bit rate (3) You may have saved your music files in a folder and copied the folder to the player. Your Sansa E250 will not recognize folders. Either save them in the root directory or inside the "Music" folder -- your player's default folder for music files. Hope this info helps :)
Apr 12, 2007 | SanDisk Sansa e250 MP3 Player
35 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
