Question about Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Brand new TV, spotty HDMI functionality (sometimes recognizes cable box or comupter, but not always). Attempted firmware update on a Sharp Aquos LC-32SH7E (European model). Don't think it ever initialized, and now get a black screen and will not respond to any buttons. Tried to perform factory reset (Un-plug power hold input and - volume same time) then plug in power. Still same result!
  • Sharp Master
  • 736 Answers
Did you go through the entire factory reset? When you plugged in the power cord did you continue to hold the volume - and input button until the television powered on and a K appeared on the screen never releasing at all?
Force the tv on by holding down channel down and volume + on the tv while plugging the tv in. See if the tv still lights up and if you get audio.
Posted on Jul 28, 2010
I need Aquos LC-37D43U firmware
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Just brought a new Sharp Aquos LC-40LE810UN. Every time I turn on the TV, using either HDMI or component cables, the input screen ALWAYS cycles between 480p and 1080i trying to find a "signal"...
This tv the tv Tuner signal board have intermittent interlacing scanning freqencies problem.Tv is new,u just bought this tv wright,return it get another one for the replacement.
Dec 11, 2010 | Sharp Televison & Video
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
HDMI audio problems with my sharp LC42D64U
the problem is that your cable box is putting out too low of a bandwidth to your tv and is cutting out completely. Since its all digital either its there or not. try switching to componant cables. Cable boxes only support up to 720p anyway so you wont sacrafice any quality.
Hope this helps
Mar 02, 2008 | Televison & Video
Hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Jan 16, 2008 | Televison & Video
Sound
This hapen only on HDMI conection. Try to update the firmware, but beeing in warranty you should call an authorized tech. If your from Montreal area I can do it for you.
Nov 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 46"LCD
You might want to try a system manufactured on the last two years most brand new components will support HDMI connections, of course the price will be a important too but you can find systems for about $200. Any brand of your liking will do just look for the HDMI logo on the box or the front of the component. If you consider to keep your amp, try to find a HDMI to AV converter I would not recommend to do this due to the fact that they are pricey and hard to find on top of that think about the loss of quality on your audio and video (personal experience).
Aug 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AQUOS LC-65SE94U 65 in. LCD HDTV Logo
338 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
