Question about Proform Exercise & Fitness
Proform xp650e, incline driving continuosly in max incline position with loud clunks/bumps
    Problem Solver:
  • 13 Answers
Your treadmill has what is called a "stair step" incline motor. It is common for them to go bad. You would need to remove the motor hood and activate the incline motor. Check to see if the noise is coming from the motor and if so I would suggest replacement.
Posted on Jul 29, 2010
Clunking noise from 09 charger front end
That sounds like a loose exhaust pipe or a metal cover plate underneath that has come loose.Check it out.
Apr 15, 2013 | 2008 Dodge Charger
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
Can I dismantle proform 360p to move it
When plugging my treadmill in it was going at max speed without the key even in. Now it has slowed to a complete stop and I can not get it to move. The incline works, but not the speed.
Jul 08, 2011 | Proform Exercise & Fitness
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
Clunking going over bumps
shocks my be going bad push up and down hard on top of the car over each front wheel and let go..it should not bounce up and down more than once. if it does shocks are bad.
Apr 08, 2010 | 2000 Chevrolet Prizm
A clunking on passengers side at rear
universal joints clunk,is it in the rear end then maybe it is the rear end.you kinda need to be more specific if this information doesn't help
Apr 23, 2009 | 1999 GMC Jimmy
Exercise & Fitness Logo
276 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
