Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
My 3516AVX is not oiling the chain, although the resevoir is filled.
  • 252 Answers
Can you verify the bar oil holes are clear?
is the breather on the oil tank working? air should be able to get in but not let oil out
can you verify the drum / sprocket is turning the pump worm gear ?
is the oil tank filter clean, not blocked, and oil line to pump clear ?
is the oil outlet passage to bar mount face clear ? if all of the above are ok then you have a faulty pump replace it and reassemble saw
refill oil tank and test
be sure to remove clutch assy turning it clockwise to remove it
it has a left hand thread
Posted on Aug 01, 2010
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
I have a POULAN PRO 3516AVX chainsaw that I have to tighten the chain after every cut . What gives?
If the chain is stretching then it is either poor quaility chain, or there is not enough oil getting to the chain, it is impotant to use a non fling chain oil so as to lubricate the bottom of the bar where most cutting is done. hold the tip of the bar close to a clean peice of card board, rev the saw, there should be a good line of oil showing on the card board.
Sep 15, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What type of oil does my black and decker chainsaw need
You can use SAE 30 weight motor oil or bar and chain oil. Press the bulb on the resevoir cap 2x before each cut making sure the saw is pointed down and to the right to let the gravity feed oiling system work properly.
Jan 05, 2011 | Black & Decker CCS818 Chain Saw
Is it bar oil that needs to be put in the resevoir
Yes; bar oil is SAE 30 with a some additives to make it adhere to your bar and chain. An excerpt from a Remington manual follows:
From your OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
Colder use SAE 10 oil.
Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
It is normal for oil to seep when saw is not in use.
Empty oil tank after each use to prevent seepage.
This is from a Remington OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Remington 16" Electric Chain Saw
Need chain oil resevoir for Remington electric
I suspect you did an on line search, we can do no better. Remington has ceased production. Parts availability is limited to what is on hand. It might be advisable to save the money you would expend for parts and put it toward the purchase of a new electric saw.
Poulan has been in business a very long time and offers 8 different models. Some can be found at Lowes. HTH
Lou
Sooner or later you will encounter a part that isn't available for your Remington. Yours may be worth more as parts than as a complete assembly. eBay?
Oct 11, 2009 | Remington Electric Chain Saw
Remington chain saw oil problem
hi,
yes sounds as if you have gummed up the port for the oiler. you will need to clean the oil resevoir out using some kerosene or mineral spirits this will clean the port out and will not be harsh on the plastic. bar and chain oil is thick but has a sticky quality or viscosity that allows it to lubricate gas engines mor effectively and uses the heat from the engine to help thin it to a consistency to be of use to the bar and chain. on an electric chain saw there is not enough heat to allow this. a good oil resevoir cleaning and replace you oil with a light weight oil recommended this should do the trick. good luck hope this helped.
Mar 30, 2009 | Remington Electric Chain Saw
Mcculloch chainsaw 2014 Eager ****** Model 00032-14
a fix that sometimes works is to add kerosene to oil tank where the oil would go normally and rev saw several times with out load holding blade in down position over a piece of dry card board so you can see the oil spraying on the piece of cardboard careful of moving chain
Jan 02, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Oct 22, 2008 | Husqvarna Chain Saw 20" Bar
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
299 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
