Question about MagLite Mag-Lite& Largehead Flashlight
No light How to switch it on/off
    Habit-Forming:
  • 37 Answers
Ok... You've put batteries in it, right? And they're fresh? Good.
The end cap is screwed in nice and firm? Finger tight is right.
You can see a globe in the lens? There's usually a replacement in the end-cap on these maglites.
The big black rubber button near the light end of the torch is an on/off switch. Press it! (Or if you want to test it, drive over it with a truck like they do in the commercials!)
Very occasionally the switch fails but they're tough and well designed. It is not a common problem.
Posted on Jul 30, 2010
Electric window will go up but not down
either your switch or window motor have gone bad. remove switch and using a test light with ignition key on test power coming out of switch by pushing window switch up and touching wire on switch it should light the test light ( wire on test light must be grounded I like to hook it on parts where door opens to get a good ground) than test down on switch by pushing switch down and touching wire on switch again it should light test light . If it lights when switch is pushed up and down switch is good and motor is bad .if switch will not light when pushed down but does light when pushed up replace switch . if this was helpful please leave me good feed back
May 23, 2013 | Ford Econoline Cars & Trucks
Trying to replace the stop light switch on a 1986 toyota 4runner
Move into a position where you can easily see underneath the driver's side of the Ford pickup's dashboard. How you do this depends on your physical size and dexterity.
Shine the flashlight on the brake pedal arm to illuminate the stop light switch and the stop light switch mounting bracket. Unplug the Ford pickup's brake light wiring harness from the switch by hand.
Read more: How do I Replace the Stop Light Switch in a 1986 Ford Pickup? ' eHow.com http://www.ehow.com/how_7655525_do-switch-1986-ford-pickup.html#ixzz21tSRtoDU
Unbolt the stop light switch from the stop light switch mounting bracket using the box wrench set. Take the old switch down by hand and place the new switch on the bracket.
Bolt the new stop light switch to the bracket with the socket set. Plug the brake light wiring harness into the Ford pickup's new stop light switch by hand.
Jul 28, 2012 | 1986 Toyota 4Runner
What causes the brake lights not come on,but allow 3rd mount light to come on? i've checked the bulbs,sockets,fuses. now i'm stumped.
THOSE LIGHTS ARE ON 2 DIFFERENT CIRCUITS. ONE WHITE WIRE COMING OUT OF THE BRAKE LIGHT SWITCH GOES TO THE CENTER BRAKE LIGHT. THE OTHER WHITE WIRE GOES FROM THE BRAKE LIGHT SWITCH TO & THROUGH THE TURN SIGNAL SWITCH SO THE LIGHTS CAN BE USED AS BRAKE LIGHTS OR TURN LIGHTS. THE BRAKE LIGHT SWITCH IS GOOD BECAUSE THE CENTER BRAKE LIGHT IS WORKING. IT IS A BAD WIRE { WHITE } FROM THE BRAKE LIGHT SWITCH TO THE TURN SIGNAL SWITCH OR A BAD TURN SIGNAL SWITCH.
Jan 17, 2011 | Buick Riviera Cars & Trucks
Need wiring for 4 light with 4(2 way switch) when on 1 switch 1 and 2 light will on when on 2 switch 1 light will off 2 and 3 light will on when on 3 switch 2 will off 3 and 4 light will on when 4 on...
i don't know about 2way switches but a three way switch that will turn a light on at both ends of a hall or off is power to one switch ,three wire between switch switch leg from other switch , make up is tie neutrals together grounds together leaving a black and red from tree wire (travelers)and a black at the switch leg (power)
Sep 24, 2010 | Home Fencing
My 1996 taurus has the brake lights constantly on. when you disconnect the switch by teh brake pedal the car will not shift out of park but teh brake lights turn off???
CHECK BRAKE LIGHT SWITCH TO SEE IF ITS TOUCHING THE BRAKE PEDAL.IF BRAKE LIGHT SWITCH OR BRACKET LOOSE AND AWAY FROM BRAKE PEDAL BRAKE LIGHT WILL STAY ON.IF BRAKE LIGHT SWITCH INTACT BRAKE LIGHT SWITCH NEED REPLACING.WHEN REPLACING BRAKE LIGHT SWITCH OR IT NEEDS ADJUSTING MAKE SURE BRAKE LIGHT SWITCH PLUNGER TOUCHES BRAKE PEDAL ARM WHEN YOU RELEASE BRAKE PEDAL BRAKE LIGHTS SHOULD TURN OFF.
Sep 01, 2010 | 1996 Ford Taurus
Brake lights dont work
Check the brake light switch, it is down on the brake pedal lever, you can dis-connect the wire connector at the brake light switch and check for broken wires at the connector, and then jumper the connector with a paper clip, if the brake lights come on then replace your brake light switch.
There might be more than one switch attached to the brake light pedal lever, the brake light switch usually only has two wires going to it when there are two switches.
If there is no problem with the brake light switch then you can suspect the turn-signal switch to be at fault, as all of the running lights, turn-signals, brake lights, and hazard lights are all ran through the turn-signal switch. You can also try stepping on the brake pedal and wiggle around the turn-signal switch and see if the brake lights flicker or come on.
Apr 26, 2010 | 2000 Jeep Grand Cherokee
No brake lights or turn signals head lights and turns work on the front and i have parking lights all around and all fuses are good
It is most likely your brake light switch. The wiring from the brake light switch goes to the turn signal switch. When the turn signal switch is centered both brake lights are connected, unless the switch is faulty. When the switch is to the left only the right light is connected to the brake light switch and vice versa. A bad switch can cause all kinds of problems with the brake lights as well as the turn signals.
To replace, locate the brake light switch at the top of the brake pedal (on the mounting bracket). Unplug the connector. Loosen the locking nut and remove the switch. Install the switch and adjust the height so the switch activates at the right position. Reconnect the connector and check for proper function.
Oct 18, 2009 | 2000 Chevrolet Cavalier
MagLite Mag-Lite& Largehead Flashlight Logo
55 people viewed this question
Top MagLite Electrical Supplies Experts
Karl Kittsteiner
lakeareaserv
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
