Question about Sentry Fireproof Safe
I HAVE A SENTRY V360 SMALL SAFE WITH A KEY AND ELECTRONIC COMBINATION BUT FORGOT THE COMBINATION HOW CAN I OPEN IT
SOURCE: sentry safe V530
Send a notarized letter stating you are the owner of the safe with the serial number and a $8.00 money order to
Sentry Group
Attn: Dept 200,882 Linden Ave
Rochester N.Y. 14625-2784
Posted on Oct 23, 2007
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
I can't remember my electronic combination.
About 24,300,000 results (0.44 seconds) Search Results
    How To: Open A Locked Sentry Safe If You Forgot ...
    ? 5:21
    https://www.youtube.com/watch?v=Mr8QrvVAtuI
    Jul 15, 2014 - Uploaded by TipsNNTricks
    I forgot my combo to my Sentry Home Safe how do I get into it? I have a .... My batteries died and I can't find the key. Anyway ...New Sentry Electronic Fire Safe Opened in Seconds with No Sign of Entry Video - Duration: 8:22.
    Dial Combination Safe Lock vs Digital Electronic Lock with ...
    ? 4:03
    https://www.youtube.com/watch?v=7Afzh4pgh-c
    Oct 6, 2011 - Uploaded by SafeandVaultStore
    Dial Combination Safe Lock vs Digital Electronic Lock with Dye the Safe Guy ... You save about a minute. ... can't get to it, then they're going to have to drill the safe open and its going to cost you somewhere in the $300-$450 ...
    Crack Almost Any Electronic Safe with the Bounce Technique
    lifehacker.com/.../crack-almost-any-electronic-safe-with-just-a...
    LifehackerIn the event you need to break into your own electronic safe, here's how to do it. ...Can't tell you how many times I hear from friends, when the last parent ... you need to bug out and having that paperwork can save you days of frustrations.
Jan 23, 2016 | Home Security
Says code error
? 5:21
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
I have the v360 sentry safe have key but forgot combination
Hi Jodie
There are certain things in life that need remembering.
This is one of them.
A Hypnotist may coax it out of you.
Otherwise....
You need a qualified Locksmith who specializes on this sort of Safe. http://www.sentrysafe.com/Products/132/V360_Security_Safe
Jul 03, 2015 | Home Security
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Sentry safe v260 . have both keys but forgot the combination. how can i over write it?
If you have a "3 number combination" or have a "4 number combination you that you have NOT changed", you can send in your serial number in a notarized letter and $8 to: Sentry Group, Dept 200, 882 Linden Ave., Rochester, NY 14625-2784. (this info is in your Owners Manual under Lost Keys or Combination) If you don't have your Owners Manual you can download it from: http://www.sentrysafe.com/products/productDetail.aspx?s=130
If you have a "4 number combination" and you HAVE changed it from the original cobmination, the only solution you have is a locksmith.
Jun 13, 2009 | Sentry Fireproof Safe
CAN NOT OPEN MY SAFE, MISPLACED INFO, LOCKED CODE NUMBER IN SAFE. ELECTRONIC FIRE SAFE NUMBERS ON OUTSIDE OF SAFE OA3817 BA69609
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
May 01, 2008 | Sentry Fireproof Safe
I lost the cobination for the safe and i cant open it
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements.
Apr 01, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
412 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
