Question about SkyGolf SkyCaddie Handheld GPS Unit
Can't download to Caddysinc
My computer screen resolution is 800x600. I cannot download to Caddysinc unless it is over 1024x768. What can I do to complete the download on my computer?
    Sergeant:
    Champion:
  • 256 Answers
Here's how you'll change the screen resolution. If your Operating System (OS) is Windows Xp or Windows 7, right click on your desktop then click on Graphics properties. It will show you a window like this: Can't download to Caddysinc - 3a2974f.jpg drop down on the resolution setup and choose your desired resolution. If, however, you are using Vista, right click on the desktop still, but this time look for Personalize. last option would be Display Settings. Click that. Then at the lower left side corner of the new window, drag the bar to your desired resolution as well. Click Apply then OK. After changing your resolution, try downloading it again to your computer. I hope this time it will work.
Posted on Jul 28, 2010
WHAT IS THE NATIVE SCREEN RESOLUTION FOR MY ACER ASPIRE X3200 ?
This depends on the monitor you have. A default resolution for a computer with no video drivers is 800x600
May 03, 2011 | Acer Aspire X3200 PC Desktop
I hook up my pc to lg lcd it always says invalid format any solution
What cable connection are you using? What resolution was the computer sending to the video graphics adapter before you connected the two?
The TV can only support
VGA Resolution: 720x400, 1360x768, 640x350, 640x480, 800x600, 1024x768, 1280x768, 1360x768 or 1366x768
HDMI to DVI: 640x350, 640x480, 800x600, 1024x768, 1280x768, 1360x768 or 1366x768
For best results you should use 1360x768.
Try resetting this when the Input is set to that for the computer. Press Menu and select Picture. Press Enter and select Screen (RGB-PC) (use the Up/Down arrows). Press Enter and select Resolution. Then press Enter and select the desired resolution. Then press Enter again.
If you like there is a Auot-config option in the Screen menu, that may set the TV properly.
If the above doesn't help, use another monitor and check the output resolution and then reconnect to the TV.
I hope this helps.
Feb 04, 2011 | LG 32LG30 32 in. LCD HDTV
I am using ubuntu 10.04 linux operating system ,but it,s screen resolution is not good .is there any possibility to download and install any vga drivers to get better resolution
Go to System, on the top bar, then Preferences and select Monitors.
On the Monitor Preference screen there will be different resolution settings that you can choose.
If there are any resolution settings higher than 800X600 like 1024X768 etc. select it and apply.
If there is no other settings available go to System then Administration and select Additional driver.
When the Additional drivers screen appears check if it recommends a a driver to be downloaded.
If it does, download the driver and then you will be able to get higher screen resolutions.
If there is no additional driver to download it gets a bit tricky.
You will need to edit your /etc/X11/xorg.conf file.
The file will look someting like this:
Section "Monitor"
Identifier "Philips 190S"
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "DPMS"
HorizSync 30-82
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Philips 190S"
Device "Default Device"
DefaultDepth 24
SubSection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
It will be wise to make a backup of this file if you are going to edit it. (xorg.conf.old)
Inside the file you will see your screen and its resolution. (Preferred mode)
You need to change the resolution, save the file and restart your session.
If all went well your resolution will be set to what you specified, if your display freaks out replace the xorg.conf file with the xorg.conf.old file.
Hope one of these options solves your problem!
Regards
Nov 28, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor blinks at random intervals at 1024x768 resolution but never at 800x600.
Your Video Card doen't support the 1024X768 that is why your first resolution is blinking and your second resolution is staying on.
Dec 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Blurred screen
There is the possiblility that this program may have corrupted the video driver or a similar issue.
You may be able to go to system restore and back the computer up a day before you installed that program...all your settings will go back to that point but any data you have added will still be there.
Aug 31, 2009 | BenQ FP71E 17" LCD Monitor
Screeen is blurred
are u using built in or external graphics . are the drivers fully upto date ??
Aug 30, 2009 | Samsung 793S 17" CRT Monitor
NVidia GeForce FX 5700LE graphic card-resolution issue
check if your monitor supports resoulution above 800x600 or something is wrong with your OS.
Jul 03, 2009 | XFX GeForce FX5700LE, (256 MB) Graphic...
Promblem resolution 1024x600 on Lenovo S10
1024x600 is not a standard screen resolution.
You can set it to 800x600 or 1024x768
Mar 28, 2009 | ASUS Eee PC 900 Notebook
Desktop view alignment
right click on your desktop and change the default resolution try 800x600, 1024x768 see if that helps. if it does not download a new videocard driver specific to your computer.
Aug 04, 2008 | Toshiba Satellite 15" Flat Panel LCD...
SkyGolf SkyCaddie Handheld GPS Unit Logo
Top SkyGolf GPS Experts
Oloyede Monsuru
Marvin
Marvin
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
