Question about Comfort-Aire HMC24AD-1 Air Conditioner
I have an Energy Knight mini split unit. One works fine the other drips condensation EXCESSIVELY. Is something wrong in the unit itself or could the drainage tube be plugged inside the wall. If so, whats the fix? Also, I have another split unit and neither will turn on. This question was asked previously and it sounds like the fuse in the outside exchanger. Exactly how do I get to this fuse to check? Thank you.
  • Heather Nichols Jun 11, 2013
    I also have an Energy Knight Air/Heat Wall Unit- and it smells sour when the air comes on....its persistent.. Help!!!
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
skrbin
  • 121 Answers
SOURCE: condensation from the coils
check drain hose maybe is obstruct or have bad plunk.
Posted on Feb 17, 2009
  • 5 Answers
SOURCE: water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Posted on Jun 12, 2009
james3751
  • 614 Answers
SOURCE: where can i get a manual for energy knight mini
go to www.heatcontroller.com you can download maual from there. Rus
Posted on Mar 17, 2010
SOURCE: Energy Knight AC Blowing Fuses
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
Posted on Jul 12, 2010
Condenser fan does not come up to full speed.
These Ptac units are advance system that are designed with variable speed motors that modulate in order to save energy, This is normal operation, because starting a motor at a lower speed rather than the conventional high speed will save energy, which translates to saving you money. As the load increases (heat) on the condenser coil, the fan will ramp up accordingly.
Aug 02, 2013 | LG LS-K2430HL Heat Cool Mini Split Air...
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Mini Split Condensation Problems!
Maybe you need to invest in a good De-Humidifier.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Water leaking at front of condensor ( inside)unit.
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
May 28, 2009 | Comfort-Aire HMC24AD-1 Air Conditioner
Condensation from the coils
Feb 12, 2009 | Sanyo 09KS51 Mini Split Air Conditioner
Comfort-Aire HMC24AD-1 Air Conditioner Logo
481 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Marvin
Marvin
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
