Question about Garmin nuvi 255W GPS Receiver
Need to switch states - Garmin nuvi 255W GPS Receiver
    President:
  • 1,514 Answers
Press where to then press address. Your present state will be shown at the top ofthe screen. At the bottom there'll be a button saying change state. Press this and select the state you want.
Posted on Jul 29, 2010
Need to wire a jeep trucks head light switch with a for ds
Jody , saved yourself a lot of trouble and go to a used junk yard or napa or auto zone and get the Factory headlight switch.
Jun 08, 2015 | Jeep Cars & Trucks
Skips "soak/prewash" function and moves from "add garment" to "wash" function. never fills with water. all hoses connected and water turned all the way on.
It sounds to me like the fill level switch is stuck, so it thinks the tub already has enough water. Since water pressure and flow vary at different installations, fill is controlled by a level sensor switch, not a timer. Typically there's a tube with one end connected to a fairly low point on the outer tub. The other end is connected to a diaphragm switch in the control panel. As water fills in the tub and tube, it forces the air in the tube into the switch, causing it to indicate a full state. If the switch is stuck in that full state, you would get the symptom you describe.
Find the parts drawings from one of the many internet parts suppliers to see where the switch and fill tube are. Take the tubing off at the top end and blow through it, in case the bottom end is clogged with lint. Then use that tubing or another piece to blow lightly into the switch, You should be able to hear it click and clack as it switches from low to full states and back.
If you know how, use an ohmmeter to check that the switch is actually changing states. Usually these switches have three terminals, Common, NO (Normally Open), and NC (Normally Closed).
--When you don't blow, there should be conduction ONLY between Common and NC. (This is the empty state which must reached before Spin will start.)
--When you are blowing, there should be conduction ONLY between Common and NO. (This is the full state which must be reached before Wash starts.)
Nov 25, 2014 | Washing Machines
Why will my asus lexus 7ins tablet not switch on
More information needed. State your initial conditions. Is the unit charged or in a state of being charged when this off state is indicated. What variations have you tried in an attempt to power the unit on?
If you have a charging source attached and if you have indication of charge being applied but the unit is currently "not switching on" press and hold the "on/off" button continuously for more than 90 secs and observe the response. What change in behavior do you see?
Jul 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Port getting flaps
sounds like some sort of keep-alive problem.
Try using
switch(config)# debug snmp packets
this will show you what is causing the line protocol to drop. you need to be connected to the console to see the output for this and turn it off when your done.
un debug all
good luck.
Jun 06, 2012 | Cisco Catalyst 4948
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
Wireless switch
I don't have this lappy, however, most newer BIOS settings show an option for a term such as "wireless state" or "Radio status" with options such as on, off, last state. The setting of "last state" should supercede any upgrades or conflicts downloaded after initial settings. Set the BIOS setting to last state and then switch it on. All subsequent boots should have wireless on. To get into BIOS settings, either F2, Delete, Spacebar, or Enter should be pressed during boot sequence. Good luck.
Jan 04, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Garmin nuvi 255W GPS Receiver Logo
180 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
