Question about HP Officejet Pro L7580 All-In-One InkJet Printer
The printer sometimes will print a half a page or if it prints at all it will print numerous pages with hearts and stars across the top. i have to cancel the print or sometimes I will unplug the all the plugs from the printer and start over. i have deleted the hp then re-installed it. I do have norton and mcafee on my computer. i have other hp printers that do not have this. I have called hp numerous times and they blame it on everthing else. also my drivers are up to date.
I'm having the same problem mate. I recently upgraded to Windows 7 and was forced to download the updated drivers. But that didn't resolve the problem either. (Yes, I was having the problem before I upgraded).
Did you ever resolve this?
Posted on Aug 05, 2010
  • Brickmodder Nov 19, 2010
    Having the same exact issue with the L7580 here too. I have uninstalled the drivers and reinstalled every driver available from the driver download page at HP for this printer to no avail. Its still printing one half page of a full page document (from multiple programs) and then printing multiple pages of one line symbols...
    Somebody help!!!
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Sometimes only prints half a page
make, model? i'm guessing that the toner (printer is of the laser type?) is running low. temporary fix, remove toner cartridge & gently shake to spread (distribute) the powder inside.
Oct 10, 2015 | Office Equipment & Supplies
I set something up to print and it only prints a half a page
Can you save your document to PDF and try to print it again? Sometimes there is 'corrupt' postscript information in your file, and when you make a PDF first, it will be solved. If you do not want to make a PDF first, try to print your document page by page. It also could be a memory problem. That sometimes will be solved by shutting down your printer, wait a minute than switch it on again. So, you can try these three things:
1: Shut down your printer, wait a minute switch it on again, than try to print your document
2: Print your document page by page
3: Make a pdf of your document first, than print the pdf
Succes!
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
Printer only prints half a page
I have a Lexmark 5400 series printer that is only printing the top half of a page. Any suggestions anyone ?.
Jan 20, 2008 | Dell A920 InkJet Printer
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
332 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
