Question about TecnoWind 75 cm (approx. 30 in.) Classic Chimney Hood w/ Push Button Control, TWD75 - BL/ WH/ SS / T...
Where do I find a replacement motor?
Where do I find a replacement motor for my 30" stainless technowind hood? It hums, but no fan - it is 6 years old.
  • 8,197 Answers
May I get the make and model # to help you more.
Posted on Jul 28, 2010
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
Ack the fan doesn't sound like it's working. When we turn it on I hear an electrical hum, but no fan sounds. Turning the fan up to 3 doesn't change the elecrtical hum, but since I can hear that I assume...
Yes Dan the hum means power is going to the fan motor but the shaft is seized. If the photo on this site depicts your rangehood you may be able to fix it. Turn the power to the unit off. Remove the upper cowling. You should be able to see the fan. Sometimes it only takes a spin of the fan and a bit of spray on lubricant on the shaft to free it up. If it spins freely then turn power on and give it a try. Some fans will be seized tight and no matter what you do they won't spin. This means it's time to get a new fan motor.
Good luck.
Feb 27, 2011 | Frigidaire (PL36PC50EC) Stainless Steel...
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Nutone range hood fan motor quit
You can remove it and bench test it by applying 120 volts to the fan leads. Do you know how to do this -- it can be dangerous if not done properly.
You can also use a voltmeter to measure resistance and check continuity of the motor coils.
May 07, 2009 | Broan-NuTone Intermediate Whispaire ...
Refrigerator hums but it stops when you open the door
Depress the door switch for the fan and light and the light should go out and the fan motor should run. If the fan motor does not run but only hums it may need to be replaced.
Apr 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Dec 16, 2007 | Broan-NuTone Intermediate Whispaire ...
TecnoWind 75 cm (approx. 30 in.) Classic Chimney Hood w/ Push Button Control, TWD75 - BL/ WH/ SS / T... Logo
373 people viewed this question
Top TecnoWind Kitchen Ranges Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Anthony Kelly
Anthony Kelly
Are you a TecnoWind Kitchen Range Expert? Answer questions, earn points and help others
