Question about Candy Dishwashers
I have a Candy Range 4 CDS 68 dishwasher. when you turn it on in any programme it makes a noise, all the lights flash and it beeps. There are no leaks, i have turned the mains power off and on. it appears to have drained correctly. When last used it completed the programme correctly. Hope you can help Peter
  • 249 Answers
SOURCE: Candy cs455 m dishwasher tripping out power
check heating element
Posted on Mar 21, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
joe_lishman
  • 192 Answers
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Posted on Mar 26, 2010
kenny444
  • 18 Answers
SOURCE: I need a manual for my candy dishwasher CFD612 can
search the internet for
NTC 49009410
Look for PDF and you may find something that helps
Posted on Apr 23, 2010
Daniel S
  • 4323 Answers
SOURCE: E3 error code on Candy
Hi
E3 error code in your Candy is a temperature error, which means that the unit is not reaching its desired temperature level. However, as the unit will heat water then it means that the heating element located on the left is fine. The next thing that should be checked is the temperature sensor (thermostat/thermister), as that might not be responding, this part is located at the bottom & can be located beneath the door. Hope this helps...please post back with its model no. for further assistance.
Daniel
Posted on Dec 08, 2010
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
How can i reset diplomat dishwasher it is stuck on a program with the 3 red buttons at the left flashing and beeping.
turn it off. switch it back on and immediatley hit the programme button 4 times within 2 seconds. This should clear the programme and reset the controller.
Aug 23, 2010 | Dishwashers
Candy Dfi 85s intergrated dishwasher
candy dishwasher wont turn on , lights are out , it is plugged in any ideas please ?
Mar 02, 2009 | Candy DFI Plan Built-In Dishwasher
Matsui MF160 Dishwasher
Unplug the cable and wait for about 15min. and then plug in cable back and turn on.
good luck
Aug 01, 2008 | Electronics - Others
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
44 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
