Question about Nintendo Wii Fit for Wii
Get repeated message of losing connection with Fitness stand on board....
  • 4,323 Answers
Hi
The lost connection issue can occur due to a number of reasons. Please make sure that the batteries are new and there are no dead ones with new ones. Also, check that the board is used on a flat surface, try adjusting the sensor bar to lower setting. However, if the above things are fine then please try and sync it again. Please refer to Wii document regarding Synchronizing your Wii Balance Board--
Synchronizing the Wii Balance Board with the Wii Console
This will surely resolve your issue. However, if the issue still persists after re-syncronizing then its a hardware issue. To resolve this issue you'll need to open up your Wii Balance board and check for the molded grid attached to the inside of Wii Board's surface.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Jul 28, 2010
HOW TO ASSEMBLE WEIGHT BENCH ?
Lay out all the pieces and check the instructions to make sure everything has been included with your weight bench. Attach the cross brace to the left upright beam and repeat the process for the right upright beam. Tighten them together with carriage bolts and set the backrest adjustment bar onto a slot on the upright beams.
Connect the main seat support beam to the cross brace with two carriage bolts, two washers, and two nuts. Do not completely tighten the nuts in place. Attach the main support beam to the front post with Allen bolts and washers. Connect the diagonal support beam to the front post in the same manner. Attach the other end of the diagonal support to the main seat support beam.
Place the arm curl stand in the front post and secure it in place with a lock knob. Tighten it down completely. Connect the leg developer post to the bracket on the front side of the front post. Attach the arm curl handle to the open bracket on the leg developer with an L-shaped lock pin.
71hekan4jtl._sl1500_-qw1ux3sfzoyydmyeq2qu2kbl-2-0.jpg Attach the bracket supports to both ends of the pivot arm of the support beam and lay the other ends on the backrest adjustment Pull up bar. Connect the backrest board to the supports with four hex bolts. Attach the seat pad with four hex bolts onto the main seat support.
Secure the preacher pad arm to the curl stand with two Allen bolts. Put two foam tubes into the leg developer halfway through the holes and attach the four foam rolls onto the ends of the tubes.
May 28, 2018 | Bench Exercise & Fitness
My 1500 treadmill will not work and on the message board it says CHECKSUM FAIL and under that says CHECKSUM PASS. What do I do to get the thing working again.
Check all the connections between the upper and lower circuit board. If those are all fine then it’s most likely the upper board that needs to be replaced.
Dec 01, 2017 | Exercise & Fitness
SAYS offline, HOW DO I GET IT BK ONLINE?
This is a network communications issue, most likely. If re-booting the copier doesn't change it, try rebooting the switch or hub it is connected to. I have seen Kyocera's take several minutes to report they are online following things as simple as being out of paper or a jam. Repeatedly trying things may cause it to stay in offline mode longer. If you are certain all panels are closed, paper and toners are in place, etc. and there are no codes or error messages, the machine should eventually be OK. If nothing works, it may be your cat5 cable or the socket in the machine. If the machine was moved with the cable still in, and it got a hard pull, there could be damage on the main board connections to the cat5 socket. that is sad and calls for board replacement.
Dec 11, 2014 | Copystar Kyocera Mita FS-C2126MFP Copier...
How do you properly execute a band side bend using an exercise band?
You will need to secure the band up high. Stand sideways and grab onto both handles with your arms stretched above your head. Then tilt your upper body to one side and then slowly bring it back after going to the other side before returning to the start position. Repeat.
Aug 05, 2012 | Exercise & Fitness
Stand by light flashes 5 times pauses and repeats. The tv works but flashes off then on.
The tv detects problem that why it indicator flashes or lose connection on the circuit or cold solder or need to solder the pin in the circuit.
Sep 24, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Lamar L1400 treadmill stopped working. The display functions properly, but after it countdowns to start, the belt does not move; then the message "lose speed" scrolls across the display. I...
Hi, please open the cover where is motor and controller board motor, and see if there are some loose cable. And if NOT tight very well all connector, and wires with a plier.
and turn ON again. If the machine after that present the same problem, you must replac the Controller board motor.
cuadra2016@yandex.com
Nov 03, 2017 | Startrac Fitness Products Lamar L1400...
My intech board for Wii fitness constantly needs to be reset////any ideas
Hmm... You should try replacing the batteries. Losing connection is usually the symptom of low batteries If that isn't the solution then I would suggest contacting the intech support line to see if they can help.
Mar 05, 2011 | Nintendo Intec Nintendo Wii Fit Action...
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
Wii board keeps telling me to press A
most likely a bad board or cable. There is a short somewhere
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Apr 23, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Nintendo Wii Fit for Wii Logo
51 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
