Nakamichi phone #'s
Hey, thanks for your help. It's probably a little too late in the evening to be calling the manufacturer though. What do you suggest?
thanks
  • 3,037 Answers
You can try
http://www.tubesandmore.com/ phone: 480.820.5411
there isn't much else you can do, just try the contact numbers for each place otherwise you will have to wait, everything doesn't seem to go the way we want it to I'm afraid
Good Luck and please let me know if you need more help
Posted on Apr 24, 2008
We have a samsung steam dryer with a 2 inch crack in drum weld. How can we fix the drum so it doesnt make the thumping nose and will still dry our clothes. We call samsung and they are not backing up there...
that sort of failure indicates an engineering and manufacture fault
even though the warranty may have run out
in consumer law there is a term "reasonable expectation" which roughly translated means that even though the warranty has run out , it is reasonably expected that the machine will perform for longer than the warranty period
Talk with a lawyer as you probably could get a new drum for the cost of the labour required to fit it
Sep 12, 2017 | Samsung Electric Steam Dryer DV331AE
Comcast Remote Code for Nakamichi Soundbar
Check out the Comcast web-site for the long list of Q and As - if nothing helps there then click on the technical support 'contact us' icon.
Good luck but be sure to give them every detail even it seems silly.
Jan 06, 2014 | Nakamichi Audio Players & Recorders
Hey, I was looking about a problem with my iphone, and I saw a post by you. It was the post about the lock button not working - mine doesn't respond at all. I don't think i can even turn off or restart my...
Hi,you will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Aug 30, 2010 | Cell Phones
Late receiver
HI
I don't think so, because there are lot of factors why your phone receives late text messages, one is coverage of the service provider and outage. try using sim card on a different phone and then check if its doing the same thing. one factor is if your phone can't pickup that good signal then chances are message will come in late, try texting your own mobile number using the 11 digit dialing patern or put 1 before your number.
hope this helps
May 12, 2009 | Nokia 6300 Cellular Phone
How Do i Fix The Sidekick2008 Hardware Problem
I'm sorry to say it is probably to late, even a little wet is still more than it should be. You should have removed the battery first thing, then let everything dry completely.
If even the least bit of water found it's way inside, and you were still using it(even just powered on), your cell could short out or cause hardware damage.
You can try taking the battery out, and placing the phone and battery inside a bowl with some rice..close it up...wait at least a full day to pull out any water that may be inside. May be to late for that to work tho.
Sorry to hear about your luck, thank you for trying Fixya!
Mar 28, 2009 | T-Mobile Sidekick
I got text but no number or name displayed
Call your phone company. Seems like your phone is having some system faults. Try taking the battery out of your phone with the power on and restarting it that way. You can't text someone private so thats not even possible. Odd, i've never seen this in my 5 years of work.....weird
Mar 21, 2009 | Motorola Mobility i530 Cellular Phone
Nakamichi AV-10 very little sound on the center speaker
could be the speaker, try connecting another speaker and cable and see if it improves. If the problem is still there and you've checked all the settings insuring that its not turned down, then could be an internal problem with the receiver.
Hope this helps a little at least.
Mar 30, 2008 | Nakamichi AV-10 Receiver
Ringtone will not work
Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Bluetooth handsfree problem
Bluetooth uses a technique called spread-spectrum frequency hopping. It changes frequencies 1,600 times every second. A frequency of 2.45 gigahertz (actually between 2.402 GHz and 2.480 GHz, to be exact). For the bluetooth device to work at 100% it needs to be 100% compatiable. More than likely, if you change your earpiece device, you should be able to pickup your songs. If you go to the VerizonWireless website, they should have 100% compatiable devices.
Todays Tivia:
Why is it called Bluetooth?
Harald Bluetooth was king of Denmark in the late 900s. He managed to unite Denmark and part of Norway into a single kingdom then introduced Christianity into Denmark. He left a large monument, the Jelling rune stone, in memory of his parents. He was killed in 986 during a battle with his son, Svend Forkbeard. Choosing this name for the standard indicates how important companies from the Nordic region (nations including Denmark, Sweden, Norway and Finland) are to the communications industry, even if it says little about the way the technology works.
Oct 20, 2007 | Motorola Mobility RAZR V3i Cellular Phone
49 people viewed this question
 Grubhead
Grubhead
