Question about Frigidaire ATF6000ES Front Load Washer
Washer will not spin, pump will not empty nor fill
I have an almost 9 years old Frigidaire front load washer. Part # fwt449gfs2 (sometimes also referenced as fwt449gf)
I checked the motor and the control board. Power doesn't seem to get to the speed control unit. I checked the voltage differential between c4.2 and c4.4 and it is null. I tested the motor protector and it was around .18 ohms (supposed to be .37).
I bypassed the motor protector to check for voltage differential (using pin 8 from the motor cable with pin c4.4) to no avail. So power is not reaching the control unit nor the motor.
Could the wax motor be at stake? What reading (resistance?) am I supposed to get out of a wax motor ?
Thanks
Jeff
  • Jeffjeffb Apr 24, 2008
    If the timer does not advance (on its own), does this mean the timer is at stake?
    Also, I do I know what step I am on the timer? Are there any indicators?
    pressure switch works only if I provide power to it. Power will not come from timer.
    so pressure works, water valves work, pump works but that was with power directly to the pump. I will have to test with a filled tub.
    Can I surely conclude it's the timer?
  • 145 Answers
Don't have resistance for wax motor. It works or it doesn't. If the door locks with 120 volts to the wax motor it is working. From your checks you have the tech sheet out of the unit so I won't go take mine apart. Check the voltage fro the timer pins that the trouble shooting says to check. Also check the pressure switch. If it reads full it will not put power to the spin. That's not in the tech sheet.
Posted on Apr 24, 2008
  • James Davis Apr 24, 2008
    Sorry it took a whlie to get back to you. The notifacation systems for comments seems to not be working so I have to check every one. If nothing is working there are a few things that can cause it. The power comes into the timer and out to the unit when you pull the knob out. The power also has to go through one door switch to know the door is closed and then to a reed switch mounted behind the dispensor drawer. There is a magnet in the drawer front that makes that switch so if you have the drawer open the machine is dead. I'v only replaced two timers on Frg front loaders ever. i'm only positive one of those was bad.
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Describe your (ATF6000ES) Front Load Washer Problem it does not spin and its 9 years old
Hi twoofdkind,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a 2 year old frigidaire front load washer.  The spin cycle starts, but only runs really slow.
all washers must drain before will go into high spin.is your's draining?the front loader type's of washers are good for getting the pumps blocked up with stuff that was in our pockets etc....too get to the pump remove the bottom front panel.the pump is the white or tan unit with two hoses to it and two wires on the right side of the washer..there are some bolts retaining the pump to the washer floor.remove and remove hose and drain into a bucket.then clean out pump.if you turn off water at house fill hose's you could put in spin at that point to test.then put all back together.if you need more advise you can email th-u fixya. God bless ,tom
Jan 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer fills washes then won't spin or rinse model FWT867GHS front load
does it empty after wash if not then pump or filter may be blocked
Jul 14, 2008 | Frigidaire FWTBB30DS Front Load Washer
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Jul 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag washer will fill but never starts cycle
motor is faulty most probably
or mayby faulty capacitor on motor
Mar 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
My frigidaire front load washer starts...then quits...
yes it could be but also it could more than likely be your pump not letting water out or not letting enough water out which stops the cycle try doing aload when it stops turn dial to empty and if it spins then your pump is faulty needs replcing thats the more common fault
Aug 11, 2007 | Frigidaire FTF530FS Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
349 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
