I have my carrier 38GQ012 where cooling machine starts for few seconds and then stops. It seems that the compressor has some trouble and does not work shutting down the system. Have you some suggestion on how to solve the problem?
22yooper
  • 828 Answers
SOURCE: Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Posted on May 31, 2008
shaggyrat
  • 1224 Answers
SOURCE: cooling
thermostat connector on grill needs to be replaced
Posted on Jun 10, 2008
  • 958 Answers
SOURCE: Whirlpool 20.8 Top won't cool neither refrigerator nor freezer
that's about right, if the compressor is drawing more than 4 amperes, then it is no good.
A reminder also to check the condenser for dirt and debris that could have accumulated at the front, this is a major contributor to compressor failure. check also the fan near the compressor. it should be running at the same time the compressor runs.
that's nice to hear from whirlpool....
good luck tapperal,
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
relaga58
  • 158 Answers
SOURCE: DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
Posted on Jun 01, 2009
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
Aircon stops after few minutes without having the room cooled the correct temp.The compressor does not start .We have to wait for a long time after shutdown and restart for it to cool again. If not
Most possible reason in this case is defective compressor(it overheats),or not enough freon in the system. Solution 1.change compressor;2.Recharge the system with freon.
Apr 02, 2014 | Carrier Heating & Cooling
Fridge cycles on and off every few seconds
sounds like the compressor can't start. could be the compressor itself, or the capacitor that kicks it on
Nov 13, 2013 | Maytag Refrigerators
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
Carrier ac model 38ckc does not cool properly. Outside unit runs but air coming out of the top is cooler than the other units that we have. Just had a service replacing all the filters and coolant checked...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new compressor
Jun 20, 2011 | Carrier 38CKC036 Air Conditioner
Switch on fridge and compressor runs for a few seconds and then stops, switch off for a few minutes and then switch on again and it runs for a few seconds. Checked thermostat and seems to be OK
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | AEG Refrigerators
I am having Daewoo refrigerator Model DIR220. When I switch on the refrigerator the compressor starts after about 3minuites and stops in few seconds. fan motor works continuously. As the compressor stops...
the compressor has an internal overload to protect it from overheating. the compressor is cooled by the refrigerant passing over it. It could be a bad compressor,, bad charge of refrigerant, or simply dirty coils not allowing air movement
Nov 26, 2009 | Dehumidifiers
Compressor won't stay on...
My guess is that you have a problem with one of the following:
Start relay...this gives a quick shot to the compressor to start the cycle...if it doesn't shut it will go to overload. The capacitor in the start circuit which assists the start relay or the compressor itself. Best bet: get a service guy in.
Dec 24, 2007 | Magic Chef CTB1521 Top Freezer...
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
