Question about Samsung CLP-610ND + Demo Laser Printer
CLP-610ND After replacing the empty yellow toner
CLP-610ND After replacing the empty yellow toner catridige the statu light turn to normal (green) color printing was resumed but there is no yellow toner transfered to the printout... B C & M seems ok thanks Remigio Grbac
Junoon007
  • 1011 Answers
SOURCE: CLP 510 error
Sir,
Inside the front cover of the Samsung CLP-510 printer is a "Waste Toner Bin" - this bin collects any toner which is not fused to the paper during the printing process. The photo at the left shows the waste toner bin installed in its correct position.As you print, the waste toner bin "fills up" with wasted toner, and you have to replace it on a regular basis. Other printers send waste toner back to a separate compartment in the toner cartridge, however Samsung prefers to sell you and additional "consumable" - apparently the $130 cost of the toner cartridges (x4 cartridges = $520/refill) just isn't sufficent revenue.
In the photo below, we see the waste toner bin removed from its operating position, and lying down on the printer door - Just tipped down from its normal place.
Note (1) - this is an optical sensor which detects when the waste toner bin is full - A "bump" on the bin (2) fits into the sensor notch when the bin is in position. An optical sensor looks though the "bump" and is supposed to detect when the toner reaches this level.
Note that one of the inlets for waste toner (3) is just above the sensor "bump" (when the bin is in it normal position). You can also see the round feed which goes into this hole, just above the sensor notch (1).
The problem occurs because the waste toner being injected into the bin "runs down the side" through the sensor "bump" - after a little while, this dirties the walls of the "bump", and although this is nowhere near as opaque as the actual toner, the sensor is sensitive enough to decide the bin is full and shuts down printing. In my opinion, this represents two fundamental flaws in the design:
  • The toner inlet should not be positioned such that toner entering the bin runs through the sensor area.
  • The optical sensor should not be so sensitive that a little dirt is detected as a full bin.
It is interesting to note that Samsung explicitly advises that you not empty and reuse the waste toner bin - The overly sensitive sensor pretty much guarantees that you cannot do this, as it is virtually impossible to empty the bin without getting toner into the sensor bump, after which the printer will refuse to print and direct you to replace the bin.
The Cure The first time this happened, I noted the dirty sensor notch and cleaned the area - It lasted only for a few pages, at which time I contacted Samsung to report the problem - No matter how I tried to explain the situation to them (over several days of correspondance) the only response I could get from them was "the bin must be full - change it".The new bin lasted for perhaps 100 pages, at which point the dreaded "replace waste toner bin" message appeared. Samsumg responded that I should clean the external sensor (I had advised them that I had tried cleaning the external sensor in my first contact with them).
TO DATE - SAMSUNG HAS REFUSED TO ACKNOWLEGE THAT THERE IS A PROBLEM IN THE DESIGN OF THE WASTE TONER SYSTEM.
To confirm my theory that toner entering the bin via the inlet was dirtying the sensor area, I added a baffle made from tape as shown on the left - This cured the problem - Note how dirty the tape has become! (It WAS clear tape)... a LOT of toner was passing through this area!
Worried that the hot toner might melt/burn the tape baffle, I have since replaced it with one made from aluminum foil - Using only a single layer, with a fairly thin part that passes through the hole and is taped in place on the outside. It is important to get the part passing through the hole to be as flat against the side as possible, as it has to fit in beside the inlet from the printer - too much thickness or wrinkles here could cause a messey leak. It is also important that the baffle NOT be so long that it would prevent the sensor notch from filling from the bottom - this could cause the printer to overflow the bin - which would not be good... I recommend that you check the waste toner bin every time you change a toner cartridge.
This link will be useful.check out the link....
https://www.office.xerox.com/partners/products/Phaser6100/Phaser6100Series.html
Don't forget to rate the solution
Good luck
Posted on Mar 11, 2008
  • 14 Answers
SOURCE: Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Posted on Dec 02, 2008
  • 193 Answers
SOURCE: Samsung printer shows empty cartridge but clearly has toner
bad chip on toner cartridge.
Posted on Feb 20, 2009
  • 1126 Answers
SOURCE: MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Posted on Aug 18, 2009
  • 11 Answers
SOURCE: refilling toner for Samsung clp 315
A reset chip is available from several vendors that overrides the printer's internal counter. This reset chip is installed on the motherboard, either by hooking tiny wires around the contacts of an IC chip, or by soldering. This reset chip is becoming easier to find. Check out ebay and other online vendors.
Posted on Mar 21, 2010
Green and amber light on together
You're almost out of toner (depending on where the light flashes, that toner needs to be replaced soon). It also can be the waste bin, that is full, in that case you have to replace the waste bin by an empty one.
Sep 27, 2011 | Samsung CLP 315 Laser Printer
I have a Samsung CLP-310 and I've mislaid the units manual. On the top of the unit down on the bottom right hand corner there are four (4) colour icons a yellow, red, blue and a grey, all which light up...
Here is the link to the manual, it says that the flashing light is PROBABLY caused by lack of toner and the first step is to replace/replenish the corresponding flashing light to the toner. It explains that when the light turns stys on all the time the toner will be empty.
With regards to the paper jamming, there is 3 pages on things to do or try.
I hope this gives you a few ideas
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=Samsung+CLP-310&input_keyword=Samsung+CLP-310
Nov 30, 2010 | Samsung CLP 300 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
I have samsung CLP610nd printer. and it's printing vertical blue smears on the paper. what is the problem and how to rectify it please
have you tried replace the (C) toner. it might be the toner drum issue. and if the rest of the color is working fine. then there is no major issue.
just replace the (C) toner will do.
May 11, 2010 | Samsung CLP-610ND + Demo Laser Printer
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
Printer will not print
if you refiller the tone cartriges yourself or by someone else then mabye the chips need to be reset. An easier way is to tape over the three copper pins on the right side then turn the printer off and when turning on hold the menu key until it says uncheck consumables mode. Unfortunatly in this mode you will not know when you are out of toner until it doesn't print right but it can get you thru in a pinch.
Feb 14, 2009 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-610ND + Demo Laser Printer Logo
44 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
