Question about Xerox Phaser 6115MFP/N Laser Printer
It's producing two vetical white strips across the page when printing.
Toner drops from the cartridge onto a dark glass (laser?) below and prevents that part of the image from being transferred. Wipe clean and the problem disappears.
Posted on Nov 04, 2010
Lines on screen
i have, a lg pdp50x30010 it has a white screen with vetical colour bands which move across screen can have replaced main board and av board and driver panel can you help pls.
Jan 09, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
When using the automatic document feeder to print,scan, or fax, the finished page displays a thin line about 5-3/8" inches from the left edge of a 8.5x11 paper. When using the flatbed, no line is...
You need to change the mylar strip on the ADF and also you need to clean the narrow strip of glass that the scanner uses for ADF scans. The Mylar strip is found by opening the lid, as you do when you put a document on the glass. On the left side you will see a Mylar sheet that covers a white backing section. There is a latch on the front and back of the Mylar mount that allows it to drop down. There should be spare Mylars in an envelope tucked under right edge of the white backing strip for documents placed on the glass. Just be sure to orient the new strip the same as the old one. The mylar strips can sometimes be cleaned but usually it is better to replace it if you have spares.
Aug 09, 2011 | HP LaserJet 4345mfp Printer
Printing with strips across print
The print-head is like a wide paint-brush going "across" the page.
If some of the hairs on the paint-brush have no paint, then you get "strips" of paint.
Similarly, for your printer, some of the ink-jets are clogged, resulting in "strips".
Use the software supplied with the printer to run a few "print-head-cleaning" cycles, to try to unclog those jets.
Mar 09, 2011 | Office Equipment & Supplies
I am having a problem printing with my HP printer
you wasted your time using cleaning program and heaps of ink...
follow this procedure:
1. remove all ink cartridges from the printer
2. check if ink is soluble in water, isopropyl alcohol or methylated spirit (this which do not create lumps or precipitations is correct solvent)
3. put one drop of solvent in th centre of aspiration hole on receptable
4. if solvent is absorbed through input, that meant problem is not with printer but with cartridges.
5. check printer cartridge by stamping them with tissue if they "produce" any ink on the outlet,
6. put one drop of solvent on cartridge outlet and insert them in correct bases
7. print test page, print should be rather weak as solvent will go through the nozzles
8. print test page from computer
9.create "strip page" of each colour used, separate by no colour (white) start with yellow strip, then white, light cyan, white, cyan, white, light magenta, white, magenta, white, black - this strip pattern will force all cartridge to operate on they max delivery.
if there is no result, service by technician will be in place...
all ink based printers need to print at least one page per week... ink will dry pretty fast, especially in dry or hot condition.
Jul 28, 2010 | HP C6250 InkJet Printer
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Error code 5100 on mx700 printer
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This part is related to the optical encoder which tells the print head where it is. Look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start up sequence. Softly clean this strip with a damp lint free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 28, 2010 | Office Equipment & Supplies
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
Xerox Phaser  6115MFP/N Laser Printer Logo
76 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
