Question about Danby DPAC8020 Air Conditioner
I have a Diplomat portable air conditioner and I have emptied the water, but it is still flashing P1 above the power button,and it wont turn on?
  • 1,992 Answers
Unplug for 15 secs
Posted on Jul 04, 2018
I was having the same problem as the OP, thanks everyone who replied to this! I didn't know what to do when on a 40°C day my AC turned off and P1 came on the display, I just needed to empty the water ! It's actually a pretty good safety feature !
Cheers!
james3751
  • 614 Answers
SOURCE: MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Posted on Jul 24, 2009
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
  • 3 Answers
SOURCE: i have an Everstar air conditioner model R51I9/BGCE. the air conditioner stopped and the LCD indicates "P1". please help. also the water indicator light is on, where is the water tank?
Usually means that you need to empty the water reservoir, or that the bucket is not seated properly.
Posted on May 23, 2009
SOURCE: My portable frigidaire air conditioner bucket light on
The actual bucket is located inside the machine at the bottom.  To access it, you must unscrew all of the screws and take the front panel off.  You cannot empty it from this side so it is not worth taking the machine apart.
However, in order to empty the bucket, there is a small black plug at the bottom left hand side at the rear of the machine.  Be careful when pulling out the plug because the water will immediately drain.
Good luck.
m
Posted on Aug 05, 2009
  • 6 Answers
SOURCE: water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
It was flashing red like the water was full. I emptied the water, put the container back in and it was still flashing. I tried to shut it off, but it wouldn't shut down.
When you unplugged it you broken the circuit which is what it does when pan is full of water to get you by turn the two wires together to make it think the switch is made
May 31, 2016 | Everstar Portable Air Conditioner MPK-10CR
P-1 code
Hello Friend, thank you for allowing me to assist you!
If you are getting an error code P1 on your Frigidaire air conditioner, normally it indicates that the bottom tray is full. Carefully remove your air conditioner to a drain location and remove the bottom drain plug and allow the water drain. Then restart your appliance and P1 symbol should disappear after you have let your appliance run. However, if the error code continues, at this point, I would recommend reaching out to a professional to proceed further. - Z
Jul 20, 2014 | Frigidaire FAP094P1Z Portable Air...
P1 code on Sylvania 12,000BTU portable AC unitl will not clear
The only thing I have been able to find as far as a P1 error code, is the water tray needs to be emptied. If thats emptied then it would be a issue with the float switch that senses the water.
Best I can find
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 21, 2013 | Sylvania Heating & Cooling
I am getting a code P1, what does it mean?
P1 Indicates that the water collection tank is full and needs to be drained. Turn the unit OFF & unplug it before attempting to drain it.
Hope this helped and thanks for choosing FixYa.
Sep 13, 2011 | Danby DPAC5070 Portable Air Conditioner
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
I have a flashing P1 and the unit will not turn on
P1 usually refers to evaporator pan full with water. If you drain it out it will work fine. If you need to reset it just unplug the power cord for two minutes.
Sep 26, 2009 | Danby DPAC8020 Air Conditioner
Alarm on on portable ac
If this is the kind I'm thinking of the condensate tank needs to be emptied of water.
Jun 02, 2009 | Royal Sovereign ARP-1008 Portable Air...
Everstar MPM1-10CR-BB6
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
Jun 17, 2008 | Danby DPAC8020 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
661 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
