Question about Hunter Ceiling Fan Control Switch
3 speed switch only works on full speed.
What do I need to tell you in order to get the right replacement?
  • 377 Answers
Make and model number of the fan is a good start. Ceiling fan or desk or pole or?????
Posted on Jul 28, 2010
I have 1985 ford full size bronco changed the wiper switch it has a delay wipers still only work on fast is it the wiper motor that is bad the wiper motor gets wet alot
you need to check the wiring from the switch to the motor with a test light and make sure its switching form the column to the motor ok. you should have a permeant 12v from the battery a permanent earth and then probably 3 more wires, a return signal from the motor to the wiper delay module that tells it when to park and your 2 speed switches from the column- one for normal speed that will go live on first speed and one for fast speed that will go live on second speed- if you have a different number of wires let me know and I should be able to tell you how to test them.
Sep 18, 2017 | Ford Cars & Trucks
My motor fans to my 1999 oldsmobile cutass need a capacitor
Charlene -
I'd guess the water temperature sensor switch is bad. Simple and relatively inexpensive to replace. If you have the ability and tools, I can tell you how to do in just a few steps.
Oct 10, 2014 | 1999 Oldsmobile Cutlass
On my Vitamix 5000 the variable speed control does not work
It will probably just need the pot replacing, take note of where the wires go. I see someone else here is doing the same job and wants to know where to put them back. Take a photo first saves a lot of grief. The pot is the rotary resistance switch behind the knob.
Mar 24, 2014 | Vitamix 5000 Work Top Blender
I have a Hampton Bay 3 speed fan. Replaced the switch that was broken but cannot get the speeds to switch correctly. fan will not turn off. and the speeds does not change. I have switched the wires around...
Most likely you have the wrong switch. You ncan't go to Home depot or Lowes and buy a generic switch off the rack and expect it to work (no matter what they tell you)Call Hunter & order switch #6378401000. 1-888-830-1326
Feb 13, 2013 | Hunter Low Profile III 20807 Ceiling Fan
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only...
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Nov 06, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
I have des 1008d switch running at 100 mbps.i want to get 200mbps speed full duplex.so please tell me how to configure this switch to get the full speed.
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.
You need to replace the switch and the network adapters with a gigabyte switch and adapters to get more bandwidth.
For more information on your switch please visit the link below:
http://www.dlink.co.in/products/?pid=183
Rashish
Aug 15, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
All speeds do not work 200monte carloheater controlswitchhow do i remove the heater switch from the dash
before you replace the swicth check the blower resistor its right behind the blower motor use a 12 volt test light hooked up to ground un hook resistor and test wires from the swicth that will tell you whats up you may need wireing diagram to correctly test the speed control wires if one one leg doesnt work the replace fan speed switch just pull plastic bezel around hvac area and remove srews pull out and remove switch
Jan 18, 2010 | 2000 Chevrolet Monte Carlo
Fan on the ac stopped working. Were is the resistor located.
I can't tell you where is the resistor but usually at maximum speed the switch bypass the resistor pack since there is no need of resistor at full speed, so if the fan stop completely, there is a good chance the fan is blown if it is not working at full speed.
Take a voltmeter and test for voltage at the fan connector with the speed fan switch on, you will be able to test all speed and if you do have voltages the fan is just dead.
Jun 01, 2009 | 2004 Jeep Grand Cherokee
Dryer hums but doesn't spin without a push
Okay, you may not need a motor but you may just need a motor switch. Get your model number and call an appliance parts store in your area and see if the switch is available. If it is then just replace the motor switch if not you will have to replace the motor. The switch is connected to the outside of the motor you will notice it because all of the wires that connect to the motor connect to it. Some of the switches have 2 screws that hold them to the motor some are riveted. If it is riveted then there probably isn't a replacement. If there are the 2 screws it most likely will be replaceable but I have seen some circumstances where it isn't. Hope this helps.
Sep 06, 2008 | Dryers
Dryers Logo
382 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
