Question about HP Office Equipment & Supplies
I have hp all in one printer . If I ever lose power, or turn off the system ,It comes on as its loading something then the bar willl not lazer across. then just makes clicking sounds as its stuck and loading. At times I can slam on it and get it to working, But it takes hours of tuning on and off and slamming
  • 52 Answers
Document scanner bad
Posted on Jul 29, 2010
HP Officejet J4550 All In One Reset Button
Hp printer/scanner J4550
1 day my parents did not power off my printer, they simply unplugged it so they can plug it into another room that had a phone jack so that they could fax something to the bank. ( too lazy to get a extra phone cable or just drive to the bank.. ) well anyways , they moved it, and plugged the power cable in.. as soon as they hit the power button, it went... CLICK CLICK CLICK CLICK CLICK... for about 1 minute.
it would let them auto print a blank sheet of paper.
but it would not let them access the fax or scan options.
the printer said read the manual ect...
its an old printer.. no manual...
But.. what i noticed is that.. this click noise was not really printer related. what it was ... was actually the scanner !
If you open the scanner door ( the top part of the printer)
you will notice that on the right side.. when you hear the clicking
its actually the scanners light wheel machine bounceing back n forth on the right side. about 1 minute after you open the door, then the light turns off and the scanner lazer wheel thing moves to the left. I noticed that on the right side.. there was some white plastic dust... you will notice how there is a line going across that kind of looks like a coat zipper with the plastic tringle's / line .
well 1 of the triangle's broke... so its like a broken coat zipper.. and the printer can't get the scanner lazer thing to the right side of the printer, so it kind of gets stuck... so basically... you need a new printer :( or if you are a plastic specialist.. or can find some type of plastic replacement, you would be able to melt some plastic or glue something idk..
well anyways, i just wanted to share my store.
the clicking on my printer came from the scanner lazer light not being able to reach the right side of the printer box b/c of a missing tringle plastic thing on a plastic line.
like i said, you could try to re-melt some plastic their, but it wouldn't last all that long... metal would work, just has to stay in the shape of the other small triangles.
( best option is to just buy a new printer )
you can get them for like 40 to 50 $ at wal-mart and they normally even come with ink...
Jun 04, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Whats the problem when computer boots, the loading progress bar og windows XP is displayed, but as soon as the computer goes into Windows XP, the screen turns black and stays black?
you coform the problem comes only when printer connected.
detach the printer cable from system and boot the system.
the problem still persist then reload the Win XP
re install the printer driver.
the problem will be solved
alexander
Apr 15, 2011 | HP LaserJet 1320 Printer
The screen on my 7410 says HP invent with a moving bar on bottom and wont respond to anything. I have turnrd power of and it keeps coming up with same. Any idea?
When the software is installed for the printer, one of the applications that is added to the system is the HP Director. There are times when this application does not open on systems that are running the Windows XP operating system. One way to correct this is to run the program from the HP program group from the "All Programs" option on the Start menu. The application will load into the computer's memory but does not appear on the screen. Press "ALT" + space bar to view the shortcut menu. Select "minimize" to display the program on the taskbar. Another option is to update the program by visiting the HP Software Download Page (see Resources).
Dec 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 8050, printer is turned on and HP invent screen comes up on the printer with a progress bar moving underneath the bar moves 2 or 3 times and then the cycle starts all over again when it restarts the...
I went through several e-mails with HP on this problem coming out with the impression that nobody was actually reading my messages, they were reacting only to "key words." So the printer has been declared junk (by me) and will be replaced at the earliest opportunity but not with HP I am tending toward an Epson or maybe a Canon.
Thanks for your interest.
Dec 12, 2009 | HP Photosmart 8050 InkJet Printer
Copys fine but it takes the paper crooked
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 24, 2009 | Lexmark X4530 InkJet Printer
The led screen shows genera error
you need to reset your printer try doing this
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
HP OfficeJet 7410
Try this partial soltion; it's worked for nearly everone who's tried it. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Sep 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
I purchased Your Digidal UPS System for my computer. I also plugged in a lazer printer. The unit turned off and showed "0" imput as I tried to print. I unplugged the The unit has not been...
Laser printers are not recommended for UPS systems because they draw large amounts of power for the fuser when printing.
The UPS should be fine with just the computer plugged in.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Aug 19, 2008 | Office Equipment & Supplies
DISPLAY READS: 80 SERVICE (01E4)
If you keep getting 80 service, first recycle the power to the printer (try a few times if the error doesn't go). If that doesn't work replace the MIO card (the bit the network cable goes in)
Jun 16, 2008 | HP LaserJet 4 plus Printer
Hp lazer 1300
The Printer's Fixing Film on the fuser assy is broken. It should be replaced. Go to a Service Center and replace the fault part.
Mar 05, 2008 | HP LaserJet 1300 Printer
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
