Question about Shure Beta 87A Professional Microphone
How find orginal shure mic?how? and how to make cable? what is balance and unbalaned cable? better balence ya unblance cable
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Unfortunately, there are many counterfeit Shure microphones out there. Each of the counterfeit manufacturers makes the fakes slightly different. Thus, there is no one thing to look for. The best thing to do is to purchase the mic from an authorized Shure dealer. Then, you can trust that it will be genuine.A balance cable has three wires (such as XLR connectors), and unbalance cable uses just two wires (such as a two conductor 1/4" connector.
Posted on Jul 28, 2010
I hear a white noise when I connect microphone with mixer (Behringer DX2000)
You posted this in questions about the Shure PG42 mic. That mic comes in two versions. There's the USB version which connects direct to a PC. Then there's the standard version which is used with a mixer. I presume you have the standard version as the Behringer doesn't have inputs for USB mics.
The standard version is a condenser mic. It needs power. The power is supplied by the mixer. It is known as phantom power because it travels up the mic cable from the mixer to the mic.
  • Make sure your mixer has phantom power switched on.
  • Use the correct mic cable: Either a 3 pin XLR to 3 pin XLR, or a 3 pin XLR to 3-pole jack (TRS). The leadis a balanced mic cable
  • Check the setting on the mic for attenuation. 0dB is no reduction in signal level. 20dB is a large reduction
  • Look at the Behringer's settings. Make sure you know what each control does and how it affects the sound. Pay particular attention to the effects send and return (FX SND RTN)
Most times there's an issue with no sound from a mic, it's usually down to a poor quality or broken cable; or no power; or the settings on the mixer.
Aug 29, 2014 | Shure PG42 Microphone
Repair cable on shure wireless headset mic
If you unplug the mic, does the crackling stop? It so, replace the mic.
Feb 03, 2012 | Shure THD Wireless Headset Microphone...
After we switch from the auto to another manual mixing board the volume on one of the mics is decreased dramatically. all other mics are not effected. both boards are linked and we have a toggle switch to...
Check the cables. If one lead of an XLR-XLR cable is shorted to ground, 6 DB gain is lost. You haven't really supplied enough information regarding cables and model of the manual mixer for us to help much. Do check that ALL of your audio interconnections are BALANCED lines either XLR to XLR or TRS cables. Grounding one side of a balanced line reduces gain 6 DB. Try swapping mic cables and channels to test where the problem is in the system.
Aug 31, 2011 | Shure Distribution Shure SCM810 8 Channel...
Hello, i've just bought a sure sm58 mic so i thought i would get a good cable to go with it, i purchased a (Planet Waves 10 feet Custom Series 1/4 inch XLR Balanced Microphone Cable) but when connected...
Where do you connect the 1/4 inch connector? At the same device (karaoke)?
Also check and report if the 1/4 inch connector is "mono" or "stereo"
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 16, 2011 | Shure SM58 Professional Microphone
New Shure PG4. RF and audio fm mic OK to PG4 but can't get mic to work with Peavy 680E. Tried different inputs, cables. Other wireless unts works OK. Wonder if pinout is wrong. Using balanced in/out.
Sounds like a complicated issue. Many things could cause this symptom. Try calling Shure at 800-516-525 to see if they can help troubleshoot.
May 04, 2011 | Shure PG42 Microphone
Shure SM58 not working. Tried on various pieces of equipment using various configurations of cables and not a sound. Took unit apart and all wiring appears to be intact. The mic has been unused for several...
The SM58 is a dynamic mic. It's actually a very simple device. Thus, it doesn't "degrade". If an SM58 fails, it usually fails catastrophically. Now, the problem for is that you don't know if the failure is in the handle (which includes a transformer) or the cartridge).
You can order a replacement cartridge from Shure and solder it in place, but might be better for you to just send the mic to Shure. I believe they will just replace the mic with a new one for their service fee.
www.shure.com/service
Nov 20, 2010 | Shure SM58 Professional Microphone
Using the Shure AMS22 with a 7V stable power source into a reg
These are a condenser mic which requires a very high impedance FET amplifier right near the condenser part. Most wired condenser mics use Phantom powering of the internal amplifier AND balanced line driver.
I would NOT recommend you try modify this unit for wired operation.
Incidently Phantom powering is usually at least 9 volts.
Dec 23, 2009 | Shure AMS22 Professional Microphone
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Washing machine
cheak see if its balence and overloadingit
Feb 03, 2008 | Whirlpool LSB6200KQ Top Load Washer
Shure Beta 87A Professional Microphone Logo
163 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
