Question about Altec Lansing VS4121 Speaker
Left Speaker Stopped Working
Suddenly, after a good year and a half or so of no problems, my left speaker (the one without the power button or volume) stopped producing sound. You could hear the faint hiss that the speakers give off when the unit is on and the volume is up, but no input; the right speaker is perfect though.
I plugged in a speaker borrowed from a 5.1 speaker set to the dysfunction left speaker plug but again, hiss, no sound. I'm guessing something internal may be bad. Any thoughts?
  • Anonymous Jun 13, 2008
    I have the same problem. Had speaker over a year and out of no where no sound from speak with power and vol control
I think I had a similar problem. My speakers were brand new and after a while I lost my front left and rear left speaker. I'm not sure about you guys but after fiddling around with the settings it worked after I changed the "S/PDIFoutput sample rate" from 48 to 96 khz. I have no clue what I did, but it worked for me. I am running logitech something or rather speakers with VIA HD audio deck drivers
Posted on Jan 29, 2009
    Problem Solver:
  • 10 Answers
Or it could be bad cables if u didnt change cables or the audio plug needs be air dusted with a can of air
Posted on Apr 24, 2008
  • Sylvester Williams
    Sylvester Williams May 09, 2008
    yeah it could be your audio broad that has the audio plugs conneted to you would need to thank it in to be service
Only half the volume on the left channel of the mixer. Why? :(
Does the left meter do the same thing? If the meter matches the right one, I would suspect the volume potentiometer on the powered speaker. Try exercising the volume knob. There might be some oxidizing on the potentiometer.
Oct 25, 2017 | Allen & Heath Xone-22 2 Channel Dj Mixer
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Jul 18, 2009 | Logitech X-230 Computer Speakers
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
May 14, 2009 | Kenwood Car Audio & Video
Only one computer speaker recieving a signal
Most probably there is a problem in the cable or plug.
Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Left speaker blown or melted?
This isn't usually in the satellite speakers. The amplifier is usually in the sub and these have a bad habbit of blowing/burning up. Return or replace. Pretty common in this model.
Sep 27, 2008 | Logitech Z-2300 Computer Speakers
Altec Lansing VS4121 Speaker Logo
1,513 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
