Question about Kenmore Dryers
80 series kenmore drum wont turn, turns manually, motor just hums
  • 5,911 Answers
If this is a Kenmore 80 series top loader it does NOT have a drive belt. This washer is manufactured by Whirlpool and uses a motor coupling in place of drive belt. This is known as a "direct-drive" configuration.
A no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem yourself and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Another secondary cause could be the drive motor.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you may need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Most of these parts are commonly sold as part of their in-store inventory.
Read through the information provided. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this is helpful to you.
Posted on Jul 29, 2010
  • 171 Answers
Most probably bad motor...  could also be broken belt.
Posted on Jul 28, 2010
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Kenmore 80 series wash machine humming
you have a clogged pump
the pump is hooked directly to the motor if thats cogged the motor cannot move producing a humming sound
Oct 07, 2009 | Washing Machines
Dryer hums but won't tumble. I can manually turn
most likely motor will need to be replaced if you do repair try to remove blower wheel first you will need a 1/2" rachet and a 7/8 for the motor to hold motor in place you may need to replace also they will lock together some times
Sep 26, 2009 | Kenmore Dryers
My kenmore, Series 80, model 110-62852101 heats, hums, but the drum does not turn. The drum is not frozen - I can rotate the drum. Reading the posts below, I believe I need to check the belt - but it is...
You are correct in thinking its the belt, that is the likely culprit, although it could be the motor, but usually the motor would give some warning before going out...humming, slowing, etc. In order to get the front panel off, you will have to first get the top off. (The top snaps over the front panel).
Jun 21, 2009 | Kenmore 64852 Electric Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
Dryers Logo
171 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
