Question about HP Office Equipment & Supplies
Offline message Printer message says Offline and won't print anymore. It will print the test page it will copy, scan. How to get it back Online so I can print.
  • 52 Answers
If the computer says printer off line then they are not comunicating try to reload driver
Posted on Jul 30, 2010
Prints a test page...but nothing else..says is offline
try on the print menu open file and you will see offline click on it to change to online and let me know again if we can try another solution
Apr 17, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 19, 2011 | Office Equipment & Supplies
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
My printer won't print from computer to printer
hi there,
1- go to your printers folder and make sure the printer is online and your P4350 is set as default (checked).
2- If offline, right click on the printer icon and try to switch it back to online. The same to make it default in case it's not.
2- Once online, then right click on the printer icon again , go to properties and then try printing a test page from windows (I am assuming you are running Windows)
3- In case you were not able to bring it back online, turn off the printer, turn off your PC, reseat the printer cable connection between the printer and the computer (both ends), then turn the printer and the computer back on.
Jun 26, 2011 | Lexmark P4350 All-In-One InkJet Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
My printer saying that offline, I can't print now. Help please
turn off your printer. check the cable, might have to unplug and plug it back. Turn printer back on. Go to control panel, printers and faxes. Right click on your printer and if still stay offline, change it back to online, and send a print test page to see if it works.
Apr 14, 2011 | Brother Office Equipment & Supplies
Printer is offline
Hi, turn it's power on. be sure the usb/data cable is connected to the cpu, if still not, remove the printer's adapter and connect it again, power it up again. if not still online, restart your pc.
When you want to print a document, you choose print and select your favorite printer but nothing happens. You look at the printer menu and see the pesky printer offline message and instant frustration. The task of the moment is going from offline to online. With creativity and patience, you'll have your printer back online in no time.
Instructions
Attempt to set the printer to online. This may not often work but it's the first action to take. Go to "Settings" and then "Printers". Right click on the "Printer" and select "Use Printer Online". Test the printer to see if it now prints.
Clear any print jobs. Double click on the "Printer" after performing the above step. Go to the "Printer Menu" and select "Cancel All Documents". There could have been a stuck print job that would cause the printer to go offline. Try once again to set the printer back online and try printing a test page.
Turn on the printer. Make sure the printer is turned on and turn it off, wait a minute and then turn it on again. Check to see if the is jammed. Check all the network connections to make sure none are loose. Repeat the above steps again if necessary.
Restart the computer. If this doesn't work, you will have to reinstall the drivers. Go to "Settings" then "Printers" and select the printer. Right click on the printer and choose "Properties". Under the "General" or "Details Tab" look for the driver button and select it and choose the driver again. You may also have to download the driver from the printer manufacturer website.
Reinstall the printer. Under "Printers" in the "Settings" menu, go back and select the printer, then delete the printer and reinstall the printer through the add printer wizard. Use the latest printer driver from the printer manufacturer's website.
Hope it helps.
Thanks for using fixya.......
Dec 06, 2010 | Epson Stylus NX100 InkJet Printer
Printer not printing
check to make sure cables are securly fastened and if it's a laser printer make sure it is set to online mode and not offline mode. Check to make sure not out of toner or ink. Make sure no other print jobs are in the way, Reset the printer. Try a printer self test and make sure the settings on the printer and computer are both set to the same. If none of this works you might have a hardware problem that needs to be fixed. if you have a warranty on the printer call the warranty company as they will fix the problem for you.
Mar 02, 2009 | HP Officejet 6310 All-In-One InkJet...
176 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
